11-17-2003 05:49 PM - edited 03-02-2019 11:46 AM
Greetings to all:
I've got an interesting ISIS problem that I can't seem to solve.
Here's the situation, basic FR hub and spoke. Hub router (call it R1) is the DIS using the priority of 127, all routers are in the same area, and configured using the is-type level-1 command. Down each spoke there are two routers. The first spoke consists of one router (call it R2) connected to the hub using FR, and the next router down the spoke (R5) is attached using a serial HDLC connection. The other spoke uses all FR, R3 is conncted to R1 using FR subint multipoint, and R3 is attached to R4 using another subint multipoint. All routers have contacted their clns neighbor.
Here is the problem. Of course R1 has all routes in it's routing table. R2 only has R1 and R5 in it's table, and the same on the other spoke R3 has only R1 and R4. But, at the end of the spokes, on routers R4 and R5, both of these routers have routes to all routes in the network. Unfortunately R4 cannot ping R5 because the intermediate routers do not have routes to the other side ot the spoke, black-holing pings.
Now, if I take the is-type level-1 command off of R1, R2, and R3, which makes the default IS type both L1 and L2 for these three routers, all routes show up in the forwarding table for all three of these routers, the other spoke shows up as L2 routes, but only temporarily.
Below is a ping from R4 up the spoke to the hub, and down the other spoke to R5.
R4#ping
Protocol [ip]:
Target IP address: 10.5.5.1
Repeat count [5]: 1000
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 1000, 100-byte ICMP Echos to 10.5.5.1, timeout is 2 seconds:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.UU.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.UU.U.U.U.U.U.U.U
.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U.U
.U.U.U.U.U.U.UU.U.U.U.U.U.U.U.U.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Success rate is 46 percent (467/1000), round-trip min/avg/max = 200/380/1280 ms
As you can see, the routes in betwen disappear and then reappear. I'm geussing that they timeout?
Any thoughts on this would be seriously appreciated.
Joe
11-17-2003 06:09 PM
I would think they are flapping because of issues with the "blind terminal," being able to see LSP's from some attached IS' on what appears to be a broadcast link, and sometimes seeing those LSP's through a different direction, etc. IS-IS doesn't really support point-to-multipoint interfaces like this, and I don't know anyone who actually has gotten it to work, even using the priorities and such. The way the PSNPs and such work, I would think that it won't work.
Russ.W
11-17-2003 06:15 PM
Thanks for the reply.
When the is-type level-1 is in place, I just find it very strange that the ends of the spokes can see all the routes in the network, but the router in between cannot. It can't be split horizon since the ends of the spoke see the updates. Any ideas why the intermediate routers would not install the routes from the other spoke?
Joe
11-18-2003 05:10 AM
Can you see the routes in the IS-IS database when it's configured as all level 1? Are the remote rotuers set to priority 0, or just the default?
Could you get the output of show isis data when it's all configured as level 1? As for the level 2 configuration, I would guess what's happening is that R1 receives R3's LSP, for instance, and installs it in it's table. It then sends out an SNP to make certain it's neighbors are sync'd, and finds that R4 doesn't have R3's LSP, so it drops those routes. When it receives a retransmitted LSP from R3, it again installs it, and the next time an SNP goes out from R1, the same thing happens again. In fact, I would venture to guess that this is a matter of R4 getting LSPs and SNPs destined for R3, rather than a strict problem with the DIS mechanism.
I'd just reconfigure the links to be point-to-point, which IS-IS supports.
Russ.W
11-18-2003 06:08 AM
The spoek routers adjacent top the hub ae configured with a ptiority of 0.
The output from show isis dat is the same whether or not the three routers are L1 or L1/L2.
Configuring a full mesh between these three routers solves the problem, but then it's not really a hub and spoke topology.
I will configure the spokes with point-to-popint, and see how that works.
Once again thanks for your input.
Joe
01-19-2004 09:32 AM
Joe,
I would be very interested to know if you ever gotthis working in a point-to-multipoint environment. I am working on the same problem and cannot seem to get this to work either. I get conflicting answers on whether a multipoint hub and spoke Frame relay configuration is supported with ISIS or not. There seems to be plenty of information indicating that it is supported.
01-19-2004 12:26 PM
I never could get this to work. i ended up using point-to-point subinterfaces, and this seemed to work. I also got conflicting info about whether this is possible or not. Let me know if you find out ottherwise.
Joe
01-20-2004 07:27 AM
I have this running now and it works fine. I would take a look at the following link.
http://www.cisco.com/warp/public/97/isis-frint.html
If you have any other questions about this let me know.
01-22-2004 11:55 AM
Do you have a frame relay network running point-to- multipoint with a full mesh, or hub and spoke? If you have it running in hub and spoke, how are your interfaces configured (physical or sub), and do you have inverse arp running at the hub or map statements? Same question on the remotes; map or inarp? The only way I was able to get this to work was with a full mesh environment. Then it didn't seem to matter if I had inarp or map statements.
01-22-2004 12:56 PM
I am runnning hub and spoke with inverse arp disabled. I am using Physical interfaces on most of the spoke routers with a few exceptions. On the Hub I am using Subs because I have a few different point-to-multi-point networks.
Here are my configs:
Hub:
interface Serial0
no ip address
encapsulation frame-relay
no frame-relay inverse-arp
frame-relay lmi-type ansi
interface Serial0.110 multipoint
ip address 189.18.110.2 255.255.255.248
ip router isis
frame-relay map clns 204 broadcast
frame-relay map clns 206 broadcast
frame-relay map ip 189.18.110.4 204 broadcast
frame-relay map ip 189.18.110.6 206 broadcast
clns router isis
isis metric 31
isis password ciscoL2 level-2
isis hello-interval 30
router isis
net 8d.0000.0001.0002.00
summary-address 196.5.128.0 255.255.192.0
domain-password ciscodomain
Spoke 1:
interface Serial0/0
ip address 189.18.110.4 255.255.255.248
ip router isis
ip nbar protocol-discovery
service-policy output CCIE
isis metric 31
isis priority 0
frame-relay map clns 402 broadcast
frame-relay map ip 189.18.110.6 402
frame-relay map ip 189.18.110.2 402 broadcast
frame-relay ip rtp header-compression
router isis
net 00.0000.0001.0004.00
is-type level-2-only
Spoke 2:
interface Serial0/0
no ip address
interface Serial0/0.110 multipoint
ip address 189.18.110.6 255.255.255.248
ip nat inside
ip router isis
isis metric 31
isis priority 0
frame-relay map clns 602 broadcast
frame-relay map ip 189.18.110.4 602
frame-relay map ip 189.18.110.2 602 broadcast
router isis
redistribute connected route-map IS-IS-R6
redistribute static ip
net 8d.0000.0001.0006.00
01-22-2004 11:00 PM
Could you possibly post the output from the sh isis topo command? Are you establishing only level-2 adjacencies? Does your routing table remain stable? I found that wne I initially started ISIS, the table would be fine, but after a couple of updates, it would get corrupted, and the other spoke route would disappear, almost as if Split horizon was preventing the updates from reaching the spokes.
Joe
01-22-2004 11:07 PM
Maybe you could also post which IOS version and on which routers you have this working. This may or may not be a factor.
Joe
01-23-2004 10:07 AM
I am running 2621XMs with 12.3(4)T2 ENTERPRISE/SNASW PLUS IPSEC 3DES, image c2600-a3jk9s-mz.12.3-4.T2.
and 3745s with 12.3(4)T2 ENTERPRISE/SNASW PLUS IPSEC 3DES, image c3745-a3jk9s-mz.12.3-4.T2.
01-26-2004 11:19 AM
Does this still work if all routers are in the same area? Of course then that pretty much means getting rid of your level-2 adjacencies only. Try putting all routers in one area with a common net, something like 49.0001.xxxx.xxxx.xxxx.00.
Joe
01-26-2004 11:19 AM
Joe
