frame/atm problem
I have a 3600 series roter with 4 atm/ima cards group together. we have a pvc back to our backbone and is bridged with a multipoint interface for our dsl customers. i have recently been trying to build a 512 frame connection to a remote site and seem to be running into dificulties. the 2600 for the remote and part of the 3600 is as follows:
The 2600 on the remote site:
JCNHSO#show running-config
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname ****!
enable secret xxx
ip subnet-zero
interface FastEthernet0/0
description to HSO Office
ip address 192.*.*.175 255.255.255.0
no ip directed-broadcast
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
no ip mroute-cache
interface Serial0/0.1 point-to-point
description to Main
bandwidth 512
ip address 205.*.*.250 255.255.255.252
no arp frame-relay
frame-relay interface-dlci 741 ietf
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0.1
no ip http server
line con 0
password xxx
login
transport input none
line aux 0
line vty 0 4
password ****
login
transport preferred none
no scheduler allocate
end
JCNHSO#
And here is the 3600: (i only took part of it) the atm/ima1.1 is the backbone back to sbc. the multipoint is for our dsl customers. pvc 7/41 is the frame to the customer.
interface ATM2/2
no ip address
atm vc-per-vp 256
no atm ilmi-keepalive
ima-group 1
no scrambling-payload
interface ATM2/3
no ip address
atm vc-per-vp 256
ima-group 1
interface ATM2/IMA1
no ip address
atm vc-per-vp 256
interface ATM2/IMA1.1 point-to-point
ip address 67.*.*.50 255.255.255.252
pvc sbcis 5/55
vbr-nrt 1500 1500 32
oam-pvc manage
encapsulation aal5mux ip
interface ATM2/IMA1.2 point-to-point
description to HSO
bandwidth 512
ip address 205.*.*.249 255.255.252
pvc 7/41
vbr-nrt 512 512 32
encapsulation aal5snap
interface ATM2/IMA1.10 multipoint
pvc 2/33
protocol ip 67.*.*.22
ubr 1544
pvc 2/34
protocol ip 67.*.*.3
ubr 1544
the pvc with 2/* are DSL customers. the 7/41 is the frame connectin. the 2600 router says serial 0/0 up, line protocol down. i dont know if its addressing or what the problem is. any help would be greatly appreciated.
Re: frame/atm problem
i was just reading an article that had a similar situation as this. on there they had the frame-relay map to the ip's. is this needed for this to work?
Silver
try
under s0/0
service module t1 timeslots 1-8
service-module t1 fdl both
if that does not work change your lmi type to cisco
that worked for the frame circuit which is now up and running. now i seem to have a routing isse. i can go from the serial interface of the 2600 all the way out of the 3600 into the world. but on the other side of the serial at the ethernet (192.*.100.175) i cant get anyone from that class out of the otherside. it can get to the .50 on the 3600 but not out.this is the final config for both the 3600 and the 2600. what route am i missing here??
2600 on Remote Site
version 12.0
hostname xxx
enable secret xxxxx
ip subnet-zero
no ip domain-lookup
ip address 192.*.100.175 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-8
description to main
bandwidth 512
ip address 67.*.201.242 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 67.*.201.241
ip route 192.*5.100.0 255.255.255.0 Serial0/0
no ip http server
end
Current configuration : 6302 bytes
version 12.2
hostname ATMIKE
enable secret xxxx/
enable password xxxx
ip subnet-zero
no ip domain-lookup
fax interface-type fax-mail
mta receive maximum-recipients 0
bridge irb
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
interface ATM2/0
no ip address
atm vc-per-vp 256
ima-group 1
interface ATM2/1
no ip address
atm vc-per-vp 256
ima-group 1
interface ATM2/2
no ip address
atm vc-per-vp 256
ima-group 1
interface ATM2/3
no ip address
atm vc-per-vp 256
ima-group 1
interface ATM2/IMA1
no ip address
atm vc-per-vp 256
ip address 67.*.193.50 255.255.255.252
pvc sbcis 5/55
oam-pvc manage
description to HSO
bandwidth 512
ip address 67.*.201.241 255.255.255.252
pvc 7/41
vbr-nrt 512 512 32
pvc 2/33
protocol ip 67.*.201.22
ubr 1544
pvc 2/35
protocol ip 67.*.201.9
ubr 1544
bridge-group 1
interface ATM2/IMA2
no ip address
interface BVI1
ip address 67.*.201.129 255.255.255.192 secondary
ip address 67.*.201.193 255.255.255.224 secondary
ip address 67.*.201.225 255.255.255.240 secondary
ip address 67.*.201.1 255.255.255.128
ip classless
ip route 0.0.0.0 0.0.0.0 67.*.193.49
ip route 192.*.100.0 255.255.255.0 67.*.201.242
no ip http server
no ip pim bidir-enable
vc-group class
bridge 1 protocol ieee
bridge 1 route ip
call rsvp-sync
end
Silver
ping a host on the 192.*.100.175 with an extended ping and source your ping from the Serial0/0.1
ping a host on the ethernet side from the serial0/0.1 on the 2600, just to clarify.
Silver
yes make sure you source it from an interface other than the ethernet , this will prove the gateways of the clients are set correctly
the people on that one can go through the 2600 down the 3600 but they cant go out the 3600 onto the real world. all there gatways are set to be the ehternet of the 2600.
Silver
If they can ping 67.*.193.50 but not 67.*.193.50 , then the .49 box has no route back to that segment
on the second one you mean the .49 box right? o.k. i understand that but i have to go to the sight in order to do that, will this fix it or is there something else i will have to do afterwards?
thank you for the help thus far
Silver
just haved a host on the 192.*.100.175 do 2 traceroutes , 1 traced to 67.*.193.50 and 1 trace to 67.*.193.49. If it makes it to 50 but not 49. then the .49 box has no route back.
I had a typo in my previous post , I meant a trace to .49 & .50
the tracert from a machine goes to the .50 but it dosnt go to the .49. what route is it that is missing?
Silver
the .49 is missing a route back to the 192.*.*.175 255.255.255.0 network , you need to advertise this network to the .49 router
so i need ip route 192.*.100.0 255.255.255.0 67.*.201.49
is this the route i need?
thanks for all the help thus far.
Silver
yes that should do it
put this in the 3600 router correct.
Silver
on the .49 router you need to add
ip route 192.*.100.0 255.255.255.0 67.*.201.50
that router is our backbone's router. i called them and told them that and they said that they shouldnt have to do that. that was what i thought as well.
Silver
how do they know how to get to that subnet then ?
i will have to ask them.
the 192.*.100.0 is the class of ip's the customer is using. sbc didnt give them to us. but they should still have to have a rote in there in order for this to work correctly but they dont seem to think.
Silver
what you are going to have to do is nat this range to the range that SBC has assigned to you
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
i understand what you are talking about but will i be able to map the 192.*.100.0 network over with only using a single ip from the 67 network?
Silver
this should work on the 2600
ip nat inside
ip nat outside
ip nat inside source list 1 interface Serial0/0.1 overload
access-list 1 permit 192.168.100.0 0.0.0.255
thanks for all the help. this worked
181
