Frame-Relay - 1720 - WIC1 CSU
Migrating from a motorola to Cisco network motorola 6450 is host (HUB Site) and 1720 is remote...circuit is a 64K what do I indicate for T1 service module? Do I need to specify channel/timeslot as 1?
Part 2:
is LMI type ANSI the ame as "Annex D"
Thank you in advance,
Bart
Re: Frame-Relay - 1720 - WIC1 CSU
all you need is to configure one channel. encapsulation should be ietf (default is cisco). LMI type really depends on what your service provider has set it to. ANSI is same as AnnexD.
When configuring the WIC, does one need to indicate a specific channel or time slot for a 64K circuit or just the number 1?
TIA
84
