Frame Relay and authentication
Before the network was made of leased lines with PPP and chap authentication. R1----R2
Now the network is built on a Frame relay network. R1--(FR)--R2
It seems the network isn't so secure as before...
How can I secure the network to get authentication between both routers R1 and R2 ?
Bernard
1 REPLY
Bronze
Re: Frame Relay and authentication
For total security, you can encrypt the traffic across the frame cloud using an IPSEC tunnel.
See the following URL for more information -
http://www.cisco.com/warp/public/707/#ipsec
282
