Webcast-Catalyst9k
Frame Relay and Routing NDS Traffic
We have recently installed a Frame Relay link to our sister company. Between Each link ate Cisco MC3810 routing NetWare 5.1 and Voice Traffic. Everythign seems to work wonderful except that when I check Time on teh servers none of them are Synced with teh Network. I read a document about the possibility that the routers may be filtering the traffic that needs to be sent for Network Time Sync.
I have searched Netware Support and Cisco's CCO with not much luck.
Anyone have any thoughts on this?
Thank you for your time and advice.
Re: Frame Relay and Routing NDS Traffic
I believe that your servers are get the time by broadcasting a time request into the network.
Broadcasts are not forwarded by a router. Therfore it seems you need to configure for Novell 5.1 an "ip helper-address" on one site on the LAN interface. See therefore URL
http://www.cisco.com/univercd/cc/td/doc/product/voice/ics7750/tblshoot/tstcp.htm
Hope this helps
regards Ulrich Marzoli
www.netaid.de
Thank you very much. It is greatly appreciated.
104
