Community Member
Frame Relay backup solution questions.
What would be the best or prefered method for backing up a frame relay circuit. The only available connection is over PSTN and external modems. Should I use the HSSI serial ports or AUX ports? How should it be configured?
Community Member
Re: Frame Relay backup solution questions.
this an exemple of configuration: backup using Async port:
interface Serial0
no ip address
no ip directed-broadcast
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0.16 point-to-point
ip address 192.168.40.2 255.255.255.0
backup delay 1 1
backup interface Async5
frame-relay interface-dlci 16 IETF
interface Async5
ip address 192.168.41.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 300 either
dialer map ip 192.168.41.1 name Tunis modem-script default 71963449
dialer hold-queue 10
dialer-group 1
async mode dedicated
pulse-time 3
no cdp enable
ppp authentication chap
then add a new route using the backup route
ip route 172.30.16.0 255.255.255.0 192.168.41.1 100
dialer-list 1 protocol ip permit
line aux 0
autoselect ppp
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 115200
flowcontrol hardware
Anonymous
N/A
So I should configure through which Serial or aux? Forgive my ingnorance....
140
