Frame Relay backup with Frame Relay with different DLCI #
j.hato
I Have 3 sites, site A, B, C. A is HQ connected with FR to B and C. B is backup site. Usually B and C connect to the server located at A. In case the A FR and server is down C and A will access to B site. So they connect to B using different FR DLCI. Is it possible.
Thanks in advance
HATO
lgijssel
Level 9
Level 9
Hello Hato,
This is possible. You will need to setup EIGRP or OSPF routing to make this work. If this is done, the rest will run automaticaly.
Leo
