Community Member
Frame-Relay Broadcast-Queue
I am needing to implement Frame-Relay Broadcast-Queue in a network I currently manage, however I can’t find any detailed information usage and how to calculate out the correct parameters. It’s a very large network currently suffering from lots of dropped eigrp broadcasts and causing, both eigrp neighbor changes and SIA issues. I’ve read all the Cisco documentation on their website, but no luck. For instance:
Do you apply the Frame-Relay Broadcast-Queue to the parent or sub-interface?
Are the calculations based upon all DLCI’s on the router, or just the parent and related sub-interfaces?
Is their a formula I could use to figure out what numbers to use for the Frame-Relay Broadcast-Queue command?
Re: Frame-Relay Broadcast-Queue
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
