Frame-relay class 3072 CIR error
I have a CISCO chasis 7204, IOS c7200-js-mz.120-9.
I try to create the following frame-relay traffic-shaping map class:
map-class frame-relay 3072ke0
no frame-relay adaptive-shaping
frame-relay cir 3072000
frame-relay bc 384000
frame-relay mincir 3072000
When entering the commands, I get following error message:
router(config)#map-class frame-relay 3072ke0
router(config-map-class)#no frame-relay adaptive-shaping
router(config-map-class)#frame-relay cir 3072000
Map Class Error: Numbers >= 2048 need trailing 0's,
44 3072000 3 3072
It look like this is a bug on this IOS and CIR is limited to 2047000 maximum.
Please confirm this.
Is there a workaround or must I upgrade the IOS???
Thanx in advance.
1 REPLY
Silver
Re: Frame-relay class 3072 CIR error
I would try upgrading. It looks like there were a few bugs on CIR in 12.0 on the 7200 platform. I couldn't find your symptoms specifically at a glance.
95
