11-18-2002 04:40 AM - edited 03-02-2019 02:57 AM
Hello
I am having issues with a 2611XM router I am trying to use. I have 8 serial ports numbered S1/0 to S1/7. I have several sub interfaces off of S1/0. My problem is, I cannot get S1/0 to come up. I get a status "up" protocol "down". And all my PVC show status deleted. I know my line is good because I can plug it back into my old 2501 and all my PVC come up without a problem. I know it must be a config issue. Can anyone tell me what I am missing? Below is the config for the 2611XM:
Current configuration : 11404 bytes
version 12.2
service timestamps debug datetime show-timezone
service timestamps log datetime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname Natick
enable secret XXXXX
enable password XXXXX
ip subnet-zero
no ip source-route
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
speed 100
full-duplex
interface Serial1/0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial1/0.3 point-to-point
description Frame Relay PVC to West Chester, PA.
ip address 192.168.254.13 255.255.255.252
frame-relay interface-dlci 876
interface Serial1/0.4 point-to-point
description Frame-Relay PVC To Allentown, PA.
ip address 192.168.254.17 255.255.255.252
frame-relay interface-dlci 227
interface Serial1/0.5 point-to-point
description Frame-Relay PVC To Sellersville, PA.
ip address 192.168.254.21 255.255.255.252
frame-relay interface-dlci 697
interface Serial1/0.6 point-to-point
description Frame-Relay PVC To Norristown, PA.
ip address 192.168.254.25 255.255.255.252
frame-relay interface-dlci 200
interface Serial1/0.7 point-to-point
description Frame-Relay PVC To Huntingdon Valley, PA.
ip address 192.168.254.29 255.255.255.252
frame-relay interface-dlci 144
interface Serial1/0.8 point-to-point
description Frame-Relay PVC To Moon Township, PA.
ip address 192.168.254.33 255.255.255.252
frame-relay interface-dlci 703
interface Serial1/0.9 point-to-point
description Frame-Relay PVC To Willowbrook, TX.
ip address 192.168.254.37 255.255.255.252
frame-relay interface-dlci 263
interface Serial1/0.10 point-to-point
description Frame-Relay PVC To West Little York, TX.
ip address 192.168.254.41 255.255.255.252
frame-relay interface-dlci 264
interface Serial1/0.11 point-to-point
description Frame-Relay PVC To Dearborn, MI.
ip address 192.168.254.45 255.255.255.252
frame-relay interface-dlci 322
interface Serial1/0.12 point-to-point
description Frame-Relay PVC To Bellaire, TX.
ip address 192.168.254.49 255.255.255.252
frame-relay interface-dlci 265
interface Serial1/0.13 point-to-point
description Frame-Relay PVC To Yipsilanti, MI.
ip address 192.168.254.53 255.255.255.252
frame-relay interface-dlci 318
interface Serial1/0.14 point-to-point
description Frame-Relay PVC To Ann Arbor, MI.
ip address 192.168.254.57 255.255.255.252
frame-relay interface-dlci 324
interface Serial1/0.16 point-to-point
description Frame-Relay PVC To Libertyville, IL.
ip address 192.168.254.65 255.255.255.252
frame-relay interface-dlci 878
interface Serial1/0.18 point-to-point
description Frame-Relay PVC To Wayne, MI.
ip address 192.168.254.73 255.255.255.252
frame-relay interface-dlci 328
interface Serial1/0.19 point-to-point
description Frame-Relay PVC To Astrodome, TX.
ip address 192.168.254.77 255.255.255.252
frame-relay interface-dlci 335
interface Serial1/0.20 point-to-point
description Frame-Relay PVC To Crafton, PA.
ip address 192.168.254.81 255.255.255.252
frame-relay interface-dlci 169
interface Serial1/0.21 point-to-point
description Frame-Relay PVC To Alpharetta, GA.
ip address 192.168.254.85 255.255.255.252
frame-relay interface-dlci 314
interface Serial1/0.22 point-to-point
description Frame-Relay PVC To Canton - Marietta, GA.
ip address 192.168.254.89 255.255.255.252
frame-relay interface-dlci 279
interface Serial1/0.23 point-to-point
description Frame-Relay PVC To Mandarin, FL.
ip address 192.168.254.93 255.255.255.252
frame-relay interface-dlci 275
interface Serial1/0.24 point-to-point
description Frame-Relay PVC To West Side, FL.
ip address 192.168.254.97 255.255.255.252
frame-relay interface-dlci 278
interface Serial1/0.25 point-to-point
description Frame-Relay PVC To New Kensington, PA.
ip address 192.168.254.101 255.255.255.252
frame-relay interface-dlci 229
interface Serial1/0.26 point-to-point
description Frame-Relay PVC To Woodlands - Houston, TX
ip address 192.168.254.105 255.255.255.252
frame-relay interface-dlci 500
interface Serial1/0.28 point-to-point
description Harper Woods, Michigan
ip address 192.168.254.113 255.255.255.252
frame-relay interface-dlci 320
interface Serial1/0.29 point-to-point
description Frame-Relay PVC To Olde Oak, TX.
ip address 192.168.254.117 255.255.255.252
frame-relay interface-dlci 773
interface Serial1/0.30 point-to-point
description Frame-Relay PVC To Crystal Lake, IL.
ip address 192.168.254.121 255.255.255.252
frame-relay interface-dlci 316
interface Serial1/0.31 point-to-point
description Frame-Relay PVC To Cleveland Heights - Cleveland, OH
ip address 192.168.254.125 255.255.255.252
frame-relay interface-dlci 504
interface Serial1/0.32 point-to-point
description Frame Relay PVC to Bedford - Cleveland, OH
ip address 192.168.254.129 255.255.255.252
frame-relay interface-dlci 506
interface Serial1/0.33 point-to-point
description Frame Relay PVC to Puritas - Cleveland, OH
ip address 192.168.254.133 255.255.255.252
frame-relay interface-dlci 508
interface Serial1/0.34 point-to-point
description Frame Relay PVC to Cuyahoga Falls - Cleveland, OH
ip address 192.168.254.137 255.255.255.252
frame-relay interface-dlci 510
interface Serial1/0.35 point-to-point
description Frame Relay PVC to Rolling Meadows - Rolling Meadows, IL
ip address 192.168.254.141 255.255.255.252
frame-relay interface-dlci 516
interface Serial1/0.36 point-to-point
description Frame Relay PVC to Southside - Jacksonville, Fl
ip address 192.168.254.145 255.255.255.252
frame-relay interface-dlci 520
interface Serial1/0.37 point-to-point
description Frame Relay PVC to Akron South - Cleveland, OH
ip address 192.168.254.149 255.255.255.252
frame-relay interface-dlci 512
interface Serial1/0.38 point-to-point
description Frame Relay PVC to Clear Lake - Houston, TX
ip address 192.168.254.153 255.255.255.252
frame-relay interface-dlci 514
interface Serial1/0.39 point-to-point
description Frame Relay PVC to Decatur - Decatur, Ga
ip address 192.168.254.157 255.255.255.252
frame-relay interface-dlci 518
interface Serial1/0.40 point-to-point
description Frame Relay PVC to Livonia- Livonia, MI
ip address 192.168.254.161 255.255.255.252
frame-relay interface-dlci 522
interface Serial1/0.41 point-to-point
description Frame Relay PVC to Duluth Duluth, GA
ip address 192.168.254.165 255.255.255.252
frame-relay interface-dlci 524
interface Serial1/0.42 point-to-point
description Frame Relay PVC to Lombard, IL
ip address 192.168.254.169 255.255.255.252
frame-relay interface-dlci 540
interface Serial1/0.43 point-to-point
description Frame Relay PVC to Morrow, GA
ip address 192.168.254.173 255.255.255.252
frame-relay interface-dlci 550
interface Serial1/0.44 point-to-point
description Frame Relay PVC to Mentor, OH
ip address 192.168.254.177 255.255.255.252
frame-relay interface-dlci 145
interface Serial1/0.45 point-to-point
description Frame Relay PVC to Glen Burnie, MD
ip address 192.168.254.181 255.255.255.252
frame-relay interface-dlci 270
interface Serial1/0.46 point-to-point
description Frame relay PVC to Irving, TX
ip address 192.168.254.185 255.255.255.252
frame-relay interface-dlci 245
interface Serial1/0.47 point-to-point
description Frame relay PVC to Grand Prairie, TX
ip address 192.168.254.189 255.255.255.252
frame-relay interface-dlci 190
interface Serial1/0.49 point-to-point
description Frame-Relay PVC to Tampa, FL
ip address 192.168.254.197 255.255.255.252
frame-relay interface-dlci 295
interface Serial1/0.50 point-to-point
description Frame-Relay PVC to Orlando, FL
ip address 10.10.50.254 255.255.255.0
frame-relay interface-dlci 370
interface Serial1/0.51 point-to-point
description Frame-Relay PVC to Downtown Houston, TX.
ip address 10.10.51.254 255.255.255.0
frame-relay interface-dlci 290
interface Serial1/0.52 point-to-point
description Frame-Relay PVC to Plano, TX
ip address 10.10.52.254 255.255.255.0
shutdown
interface Serial1/0.53 point-to-point
description Frame-Relay PVC to FT. Worth, TX
ip address 10.10.53.254 255.255.255.0
frame-relay interface-dlci 375
interface Serial1/0.54 point-to-point
description Frame-Relay PVC to Dallas, TX
ip address 10.10.54.254 255.255.255.0
frame-relay interface-dlci 380
interface Serial1/0.55 point-to-point
description Frame-Relay PVC To Blue Island, TX.
ip address 10.10.55.254 255.255.255.0
frame-relay interface-dlci 205
interface Serial1/0.56 point-to-point
description Frame-Relay PVC To Midvale, UT.
ip address 10.10.56.254 255.255.255.0
shutdown
interface Serial1/0.57 point-to-point
description Frame-Relay PVC to Penn Hills, PA.
ip address 10.10.57.254 255.255.255.0
shutdown
interface Serial1/0.58 point-to-point
description Frame-Relay PVC To Thornton, CO.
ip address 10.10.58.254 255.255.255.0
shutdown
interface Serial1/0.59 point-to-point
description Frame-Relay PVC To Pinellas Park, FL
ip address 10.10.59.254 255.255.255.0
shutdown
interface Serial1/0.60 point-to-point
description Frame-Relay PVC To Lewsiville, TX
ip address 10.10.60.254 255.255.255.0
interface Serial1/1
ip address 10.10.11.1 255.255.255.0
interface Serial1/2
description Test Network
ip address 192.168.254.201 255.255.255.252
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 172.0.0.0
network 192.168.2.0
network 192.168.254.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 172.26.0.0 255.255.0.0 172.25.66.245
ip http server
ip pim bidir-enable
snmp-server community XXXX RW 1
snmp-server enable traps tty
dial-peer cor custom
banner motd ^CCCCCCCC
| Sterling Autobody |
| This is a private computer network. |
| UNAUTHORIZED ACCESS OR USE |
| IS PROHIBITED AND IS PUNISHABLE |
| UNDER FEDERAL, STATE & LOCAL LAW |
+---------------------------------------------+^C
line con 0
session-timeout 25
exec-timeout 25 0
password XXXXX
flowcontrol hardware
line aux 0
transport input all
line vty 0 4
session-timeout 25
exec-timeout 25 0
password XXXXXX
login
end
Natick#
11-18-2002 08:18 AM
are you using an internal CSU ? If so you need to set the timeslots.
Have you verified the lmi-type that is being used by the local FR switch ?
11-18-2002 08:27 AM
No, I am using an external Adtran CSU, and I have verified the lmi-type also.
thanks!
11-18-2002 08:33 AM
If the adtran is a TSU IQ+ you can check on the view statistics section, if the DLCIs are active
Do you see any alarms (LED) on the CSU ???
11-18-2002 09:56 AM
Have you tried to change your encap to HDLC to see if the line goes up/up ?
11-18-2002 11:43 AM
I have not tried that, can I use HDLC with frame-relay? Im new here so bear with me...
11-18-2002 12:50 PM
have you tried
encapsulation frame-relay ietf
