You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Frame Relay Config Problems On A 2611XM
Hello
I am having issues with a 2611XM router I am trying to use. I have 8 serial ports numbered S1/0 to S1/7. I have several sub interfaces off of S1/0. My problem is, I cannot get S1/0 to come up. I get a status "up" protocol "down". And all my PVC show status deleted. I know my line is good because I can plug it back into my old 2501 and all my PVC come up without a problem. I know it must be a config issue. Can anyone tell me what I am missing? Below is the config for the 2611XM:
Current configuration : 11404 bytes
version 12.2
service timestamps debug datetime show-timezone
service timestamps log datetime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname Natick
enable secret XXXXX
enable password XXXXX
ip subnet-zero
no ip source-route
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
speed 100
full-duplex
interface Serial1/0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial1/0.3 point-to-point
description Frame Relay PVC to West Chester, PA.
ip address 192.168.254.13 255.255.255.252
frame-relay interface-dlci 876
interface Serial1/0.4 point-to-point
description Frame-Relay PVC To Allentown, PA.
ip address 192.168.254.17 255.255.255.252
frame-relay interface-dlci 227
interface Serial1/0.5 point-to-point
description Frame-Relay PVC To Sellersville, PA.
ip address 192.168.254.21 255.255.255.252
frame-relay interface-dlci 697
interface Serial1/0.6 point-to-point
description Frame-Relay PVC To Norristown, PA.
ip address 192.168.254.25 255.255.255.252
frame-relay interface-dlci 200
interface Serial1/0.7 point-to-point
description Frame-Relay PVC To Huntingdon Valley, PA.
ip address 192.168.254.29 255.255.255.252
frame-relay interface-dlci 144
interface Serial1/0.8 point-to-point
description Frame-Relay PVC To Moon Township, PA.
ip address 192.168.254.33 255.255.255.252
frame-relay interface-dlci 703
interface Serial1/0.9 point-to-point
description Frame-Relay PVC To Willowbrook, TX.
ip address 192.168.254.37 255.255.255.252
frame-relay interface-dlci 263
interface Serial1/0.10 point-to-point
description Frame-Relay PVC To West Little York, TX.
ip address 192.168.254.41 255.255.255.252
frame-relay interface-dlci 264
interface Serial1/0.11 point-to-point
description Frame-Relay PVC To Dearborn, MI.
ip address 192.168.254.45 255.255.255.252
frame-relay interface-dlci 322
interface Serial1/0.12 point-to-point
description Frame-Relay PVC To Bellaire, TX.
ip address 192.168.254.49 255.255.255.252
frame-relay interface-dlci 265
interface Serial1/0.13 point-to-point
description Frame-Relay PVC To Yipsilanti, MI.
ip address 192.168.254.53 255.255.255.252
frame-relay interface-dlci 318
interface Serial1/0.14 point-to-point
description Frame-Relay PVC To Ann Arbor, MI.
ip address 192.168.254.57 255.255.255.252
frame-relay interface-dlci 324
interface Serial1/0.16 point-to-point
description Frame-Relay PVC To Libertyville, IL.
ip address 192.168.254.65 255.255.255.252
frame-relay interface-dlci 878
interface Serial1/0.18 point-to-point
description Frame-Relay PVC To Wayne, MI.
ip address 192.168.254.73 255.255.255.252
frame-relay interface-dlci 328
interface Serial1/0.19 point-to-point
description Frame-Relay PVC To Astrodome, TX.
ip address 192.168.254.77 255.255.255.252
frame-relay interface-dlci 335
interface Serial1/0.20 point-to-point
description Frame-Relay PVC To Crafton, PA.
ip address 192.168.254.81 255.255.255.252
frame-relay interface-dlci 169
interface Serial1/0.21 point-to-point
description Frame-Relay PVC To Alpharetta, GA.
ip address 192.168.254.85 255.255.255.252
frame-relay interface-dlci 314
interface Serial1/0.22 point-to-point
description Frame-Relay PVC To Canton - Marietta, GA.
ip address 192.168.254.89 255.255.255.252
frame-relay interface-dlci 279
interface Serial1/0.23 point-to-point
description Frame-Relay PVC To Mandarin, FL.
ip address 192.168.254.93 255.255.255.252
frame-relay interface-dlci 275
interface Serial1/0.24 point-to-point
description Frame-Relay PVC To West Side, FL.
ip address 192.168.254.97 255.255.255.252
frame-relay interface-dlci 278
interface Serial1/0.25 point-to-point
description Frame-Relay PVC To New Kensington, PA.
ip address 192.168.254.101 255.255.255.252
frame-relay interface-dlci 229
interface Serial1/0.26 point-to-point
description Frame-Relay PVC To Woodlands - Houston, TX
ip address 192.168.254.105 255.255.255.252
frame-relay interface-dlci 500
interface Serial1/0.28 point-to-point
description Harper Woods, Michigan
ip address 192.168.254.113 255.255.255.252
frame-relay interface-dlci 320
interface Serial1/0.29 point-to-point
description Frame-Relay PVC To Olde Oak, TX.
ip address 192.168.254.117 255.255.255.252
frame-relay interface-dlci 773
interface Serial1/0.30 point-to-point
description Frame-Relay PVC To Crystal Lake, IL.
ip address 192.168.254.121 255.255.255.252
frame-relay interface-dlci 316
interface Serial1/0.31 point-to-point
description Frame-Relay PVC To Cleveland Heights - Cleveland, OH
ip address 192.168.254.125 255.255.255.252
frame-relay interface-dlci 504
interface Serial1/0.32 point-to-point
description Frame Relay PVC to Bedford - Cleveland, OH
ip address 192.168.254.129 255.255.255.252
frame-relay interface-dlci 506
interface Serial1/0.33 point-to-point
description Frame Relay PVC to Puritas - Cleveland, OH
ip address 192.168.254.133 255.255.255.252
frame-relay interface-dlci 508
interface Serial1/0.34 point-to-point
description Frame Relay PVC to Cuyahoga Falls - Cleveland, OH
ip address 192.168.254.137 255.255.255.252
frame-relay interface-dlci 510
interface Serial1/0.35 point-to-point
description Frame Relay PVC to Rolling Meadows - Rolling Meadows, IL
ip address 192.168.254.141 255.255.255.252
frame-relay interface-dlci 516
interface Serial1/0.36 point-to-point
description Frame Relay PVC to Southside - Jacksonville, Fl
ip address 192.168.254.145 255.255.255.252
frame-relay interface-dlci 520
interface Serial1/0.37 point-to-point
description Frame Relay PVC to Akron South - Cleveland, OH
ip address 192.168.254.149 255.255.255.252
frame-relay interface-dlci 512
interface Serial1/0.38 point-to-point
description Frame Relay PVC to Clear Lake - Houston, TX
ip address 192.168.254.153 255.255.255.252
frame-relay interface-dlci 514
interface Serial1/0.39 point-to-point
description Frame Relay PVC to Decatur - Decatur, Ga
ip address 192.168.254.157 255.255.255.252
frame-relay interface-dlci 518
interface Serial1/0.40 point-to-point
description Frame Relay PVC to Livonia- Livonia, MI
ip address 192.168.254.161 255.255.255.252
frame-relay interface-dlci 522
interface Serial1/0.41 point-to-point
description Frame Relay PVC to Duluth Duluth, GA
ip address 192.168.254.165 255.255.255.252
frame-relay interface-dlci 524
interface Serial1/0.42 point-to-point
description Frame Relay PVC to Lombard, IL
ip address 192.168.254.169 255.255.255.252
frame-relay interface-dlci 540
interface Serial1/0.43 point-to-point
description Frame Relay PVC to Morrow, GA
ip address 192.168.254.173 255.255.255.252
frame-relay interface-dlci 550
interface Serial1/0.44 point-to-point
description Frame Relay PVC to Mentor, OH
ip address 192.168.254.177 255.255.255.252
frame-relay interface-dlci 145
interface Serial1/0.45 point-to-point
description Frame Relay PVC to Glen Burnie, MD
ip address 192.168.254.181 255.255.255.252
frame-relay interface-dlci 270
interface Serial1/0.46 point-to-point
description Frame relay PVC to Irving, TX
ip address 192.168.254.185 255.255.255.252
frame-relay interface-dlci 245
interface Serial1/0.47 point-to-point
description Frame relay PVC to Grand Prairie, TX
ip address 192.168.254.189 255.255.255.252
frame-relay interface-dlci 190
interface Serial1/0.49 point-to-point
description Frame-Relay PVC to Tampa, FL
ip address 192.168.254.197 255.255.255.252
frame-relay interface-dlci 295
interface Serial1/0.50 point-to-point
description Frame-Relay PVC to Orlando, FL
ip address 10.10.50.254 255.255.255.0
frame-relay interface-dlci 370
interface Serial1/0.51 point-to-point
description Frame-Relay PVC to Downtown Houston, TX.
ip address 10.10.51.254 255.255.255.0
frame-relay interface-dlci 290
interface Serial1/0.52 point-to-point
description Frame-Relay PVC to Plano, TX
ip address 10.10.52.254 255.255.255.0
shutdown
interface Serial1/0.53 point-to-point
description Frame-Relay PVC to FT. Worth, TX
ip address 10.10.53.254 255.255.255.0
frame-relay interface-dlci 375
interface Serial1/0.54 point-to-point
description Frame-Relay PVC to Dallas, TX
ip address 10.10.54.254 255.255.255.0
frame-relay interface-dlci 380
interface Serial1/0.55 point-to-point
description Frame-Relay PVC To Blue Island, TX.
ip address 10.10.55.254 255.255.255.0
frame-relay interface-dlci 205
interface Serial1/0.56 point-to-point
description Frame-Relay PVC To Midvale, UT.
ip address 10.10.56.254 255.255.255.0
shutdown
interface Serial1/0.57 point-to-point
description Frame-Relay PVC to Penn Hills, PA.
ip address 10.10.57.254 255.255.255.0
shutdown
interface Serial1/0.58 point-to-point
description Frame-Relay PVC To Thornton, CO.
ip address 10.10.58.254 255.255.255.0
shutdown
interface Serial1/0.59 point-to-point
description Frame-Relay PVC To Pinellas Park, FL
ip address 10.10.59.254 255.255.255.0
shutdown
interface Serial1/0.60 point-to-point
description Frame-Relay PVC To Lewsiville, TX
ip address 10.10.60.254 255.255.255.0
interface Serial1/1
ip address 10.10.11.1 255.255.255.0
interface Serial1/2
description Test Network
ip address 192.168.254.201 255.255.255.252
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 172.0.0.0
network 192.168.2.0
network 192.168.254.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 172.26.0.0 255.255.0.0 172.25.66.245
ip http server
ip pim bidir-enable
snmp-server community XXXX RW 1
snmp-server enable traps tty
dial-peer cor custom
banner motd ^CCCCCCCC
| Sterling Autobody |
| This is a private computer network. |
| UNAUTHORIZED ACCESS OR USE |
| IS PROHIBITED AND IS PUNISHABLE |
| UNDER FEDERAL, STATE & LOCAL LAW |
+---------------------------------------------+^C
line con 0
session-timeout 25
exec-timeout 25 0
password XXXXX
flowcontrol hardware
line aux 0
transport input all
line vty 0 4
session-timeout 25
exec-timeout 25 0
password XXXXXX
login
end
Natick#
  • Other Network Infrastructure Subjects
Silver
Re: Frame Relay Config Problems On A 2611XM
are you using an internal CSU ? If so you need to set the timeslots.
Have you verified the lmi-type that is being used by the local FR switch ?
No, I am using an external Adtran CSU, and I have verified the lmi-type also.
thanks!
If the adtran is a TSU IQ+ you can check on the view statistics section, if the DLCIs are active
Do you see any alarms (LED) on the CSU ???
Silver
Have you tried to change your encap to HDLC to see if the line goes up/up ?
I have not tried that, can I use HDLC with frame-relay? Im new here so bear with me...
have you tried
encapsulation frame-relay ietf
303
