Frame Relay configuration help
I have two sites that I will connect using a fractional 128k frame relay. I am using cisco 2621 routers on both sites with WIC cards in them. I got the DLCI numbers and the LMI type that will be using by the TELCO and I need help in configuring the interfaces.
This is what I have so far. I know I am missing something because I still getting line protocol down.
Router site A
bandwidth 128
ip address 10.10.10.2 255.255.255.0
encapsulation frame-relay
no ip mroute-cache
frame-relay interface-dlci 30
frame-relay lmi-type ansi
Router Site B
bandwidth 128
ip address 10.10.10.1 255.255.255.0
no ip mroute-cache
Thank you in advance for you help!!
Re: Frame Relay configuration help
I assume you are using WIC1-DSU cards in your 2620s -- in other words, full T-1 cards. You need another statement to tell the router's internal CSU that you are using only a fraction of the T-1.
Here is the command:
service-module t1 timeslots 1-2
Put it in on both sides.
Michael Young
Infiniplex
in case you are not connected to a frame relay device other than Cisco you must use IETF encapsulation by using
ENCAPSULATION FRAME-RELAY IETF
on both sides.
I also recommend you to define IP and DLCI in subinterface rather than defining on physical port.
84
