Community Member
Frame-Relay DLCI changes are not logging to syslog
We just replaced an old 2500 with a new 2621XM. The thing is, the old 2500 would log to a syslog everytime a DLCI's status changed from "ACTIVE to INACTIVE or DELETED", but since the new 2621 has been in place, it hasn't logged any DLCI changes. The only way I can tell when a DLCI goes down is from a SNMP Trap. Is there something I am missing in the config, or is it an IOS issuse? One other thing, it does log everything else.
logging history debugging
logging trap errors
logging 10.5.2.109
logging 10.5.2.45
logging 10.5.2.108
snmp-server community xxxx RO
snmp-server community xxxxx RW
snmp-server trap-source FastEthernet0/0
snmp-server enable traps frame-relay
snmp-server host 10.5.2.108 xxxxx
snmp-server host 10.5.2.109 xxxxx
Bronze
Re: Frame-Relay DLCI changes are not logging to syslog
Give the following commands on the interface. That should help.
logging event subif-link-status
logging event dlci-status-change
Ciao
Roger
Community Member
Sorry about that, those commands were in there. That was the first thing I tried.
interface Serial0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
cdp enable
frame-relay class gaming
frame-relay traffic-shaping
frame-relay lmi-type ansi
hold-queue 100 out
Bronze
Hi again
tja, i guess it should work, especially because the router should send all the
traps anyway.
I had it ones on a cisco 7200 router that he only send the traps linkup/down when i enabled the following command:
snmp-server enable traps snmp
the router the did take the following into the configuration:
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
But as i said this was on a different platform.
Roger
195
