Community Member
Frame Relay DLCI question
Hello all. When configuring Frame Relay with dynamic address mapping, do I need a DLCI if I am using the top level interface? IE: serial 0
Thanks!
Robert
Community Member
Re: Frame Relay DLCI question
Let me edit it the above question. In the "real world" is the above situation normally not done? That is when implementing Frame Relay, are subinterfaces typically used? And therefore one would use a DLCI on the subinterface as normal.
Robert
It becomes much simpler to manage, when using subinterfaces. Mostly people prefer using sub ints, rather than using physical ints.
Whether you use a subint or physical int. you will need one pvc for each remote site you are communicating to. If you have 10 remote sites, you can reuse the same dlci number for the remote sites, and use different dlci numbers for each pvc terminating at the HO. Like below:
HQ --dlci 101 to dlci 100 ----remote1
--dlci 102 to dlci 100 ----remote2
--dlci 103 to dlci 100 ----remote3
--dlci 104 to dlci 100 ----remote4
Even though the remotes are having same dlci configured, the PVCs are unique.
Community Member
You will need a DLCI with each link doesn't matter you use main interface or subinterface
/Bessie
100
