frame relay dlci's
carl_townshend
if I am using multipoint, can i just use 1 dlci ? and if im using point to point do I need multiple dlci's to reach my destinations ?
cheers
Carl
8 Replies 8
mahmoodmkl
Level 7
Level 7
HI
i think u cannot becoz u will be having different multipoint locations which require their own DLCI's
Mahmood
devang_etcom
Level 7
Level 7
no you need to have multiple dlci wheter you will go for multipoiont or point to point...
regards
Devang
whats the benefit of multipoint then ?
in multipoint configuration you will have all your spoke and hub routers in the same subnet...and in point to point you can have different subnet with each spoke...and in wan it is recomandad to use the point to point ...and the design is depends on your requirement...
rate this post if it helps
regards
Devang
so what are the main differences in multipoint and multipoint, why have both ?
are you looking for the point to point and multipoint difference or what???
I want to know why there are basically 2 options ? why not use point to point all the time ?
can anyone help me decide which is the best to use and why ?
