Webcast-Catalyst9k
frame-relay encryption
What are my option for encrypting data over frame- relay? Can this be done with cisco ios?
Re: frame-relay encryption
Try these links:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/secur_c/scprt4/scencryp.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/secur_c/scprt4/scencryp.htm#20881
http://www.cisco.com/warp/public/707/16.html and
http://www.cisco.com/cgi-bin/Support/PSP/psp_view.pl?p=Internetworking:IPSec
I haven't done it myself, but the answer is that depends on your IOS, equipment, and your links. After reading all the documentation, you should be able to make an informed decision as to whether your network can support encryption (most networks can).
Try this link. Nice Box
www.cylink.com
why? the purpose of a frame relay network is to provide a private link between two sites. a frame relay link sold to you to connect two sites is private. no encryption necessary. that being said, if management wants it, then you should look into IPSEC. it is supported on most cisco boxes with 12.x IOS>
715
