03-26-2002 01:18 PM - edited 03-01-2019 09:02 PM
2611 router received SegV exception and reboots continually when connected to Frame Relay circuit.
03-27-2002 01:19 AM
which version of IOS are you using ? seems like an IOS Bug........
03-27-2002 04:56 AM
IOS version 12.0(7)T. It's a T1 Frame Relay connection with the WIC1/DSU. The s0 interface is using the service-module T1 timeslots command. Is this the correct usage of this command?
03-27-2002 04:59 AM
Also, I did find information on Cisco's website regarding this issue. They say the SegV exception error is always a software issue. Their first recommendation is to up grade to the latest version of the IOS. That will be my next step once I can confirm that the interface config is correct.
Thank You, Dan
04-03-2002 12:49 PM
Issue resolved. The router required an operating system upgrade.
