Webcast-Catalyst9k
Frame-Relay from a 7206 to a MartisDXX
I am attempting to connect a single E1 channel to a Martis DXX using frame-relay.
Till now, no success.
I have setup a subinterface which has the state of "interface up, line protocol up".
The subinterface has an address.
The cisco is sending LMI requests, but receiving no answer.
I can ping the subinterface from outside the router (my pc) but cannot ping it from the router itself.
I have gone through documents, but so far I am at a loss.
Lutz.
VIP Purple
Re: Frame-Relay from a 7206 to a MartisDXX
can you post your configuration ? As far as I remember, in order to ping the interface from your router, you need to map a local DLCI to the IP address of that router.
GP
interface Serial3/6:0
description Frame-Relay Test
bandwidth 64
no ip address
no ip directed-broadcast
no ip proxy-arp
encapsulation frame-relay IETF
no fair-queue
no frame-relay broadcast-queue
interface Serial3/6:0.1 point-to-point
bandwidth 64
ip address xxx.xxx.xxx.xxx 255.255.255.252
no cdp enable
frame-relay interface-dlci 100
And here some "Show" commands:
show frame-relay pvc
PVC Statistics for interface Serial3/6:0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 1 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial3/6:0.1
input pkts 0 output pkts 7168 in bytes 0
out bytes 525358 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
pvc create time 04:26:13, last time pvc status changed 00:48:08
#show frame-relay lmi
LMI Statistics for interface Serial3/6:0 (Frame Relay DTE) LMI TYPE = CCITT
Invalid Unnumbered info 0 Invalid Prot Disc 0
Invalid dummy Call Ref 0 Invalid Msg Type 0
Invalid Status Message 0 Invalid Lock Shift 0
Invalid Information ID 0 Invalid Report IE Len 0
Invalid Report Request 0 Invalid Keep IE Len 0
Num Status Enq. Sent 1619 Num Status msgs Rcvd 1614
Num Update Status Rcvd 0 Num Status Timeouts 7
The funny thing is that I seem to be getting LMI status reports accross, but no data.
I have tried a number of configs, but none seem to get the data going.
show int ser 3/6:0.1
Serial3/6:0.1 is up, line protocol is up
Hardware is Multichannel E1
Internet address is xxx.xxx.xxx.xxx/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY IETF
Oh, and in case there is any misunderstanding - the pc I use to ping the interface on the router is on some other ethernet interface of that router, there is NO traffic going across the FR link.
On the FR 'link' I have the 7206 router on one side and a Tellabs 8110 bridge on the other.
123
