04-04-2003 02:23 PM - edited 03-02-2019 06:25 AM
What would cause the interface broadcast counter to constantly incrementing?
Serial0/2 is up, line protocol is up
Hardware is PowerQUICC Serial
Description: Athena F/R Cloud via BellSouth #L2HCG5578579
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 30/255, rxload 14/255
Encapsulation FRAME-RELAY, loopback not set
Keepalive set (10 sec)
LMI enq sent 149, LMI stat recvd 149, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 4613/0, interface broadcasts 4163
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:24:41
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/12/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 87000 bits/sec, 34 packets/sec
5 minute output rate 186000 bits/sec, 39 packets/sec
46755 packets input, 12217933 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
49990 packets output, 33356196 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
04-04-2003 03:23 PM
Routing protocol traffic (hellos, updates, etc)
04-04-2003 09:52 PM
You may be having the routing protocol running over this serial link with "frame-relay-map ip.." command to map ip address with dlci. Now doyou have "broadcast" used with that frame-relay map command?
Many broadcasts are because of routing updates over that link.
Pl. post the config here to comment on that.
