For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
frame-relay/ip conectivity
I have a 1721 with 12.3 software and the attached config. The isdn link works fine. The frame-relay link is not. All three links are connected to 3com NB11's. From the 1721 I cannot ping the two serial subinterfaces or the far end connection. However from the 3com I can ping it's local interface and the ones on the 1721. SH INT says that the interfaces are up, up. SH FRAME_RELAY PVC says that the pvc's are active connected and packets are being passed. I have checked ip address's and subnet masks and all appear correct. Help!
version 12.3
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface Loopback0
ip address xxx.xxx.24.24 255.255.255.255
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
interface FastEthernet0
ip address xxx.xxx.31.1 255.255.128.0
ip directed-broadcast
speed auto
half-duplex
no cdp enable
interface Serial0
no ip address
ip helper-address 23.200.127.255
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0.16 point-to-point
description Backup PVC to LM
bandwidth 256
ip address xxx.xx.4.129 255.255.255.128
ip ospf authentication-key cisco
ip ospf cost 4000
no cdp enable
frame-relay class data
frame-relay interface-dlci 16
interface Serial0.17 point-to-point
description Primary link to HQ
bandwidth 256
ip address xxx.xxx.4.1 255.255.255.128
no cdp enable
frame-relay interface-dlci 17
interface Dialer1
ip address xxx.xxx.9.2 255.255.255.128
encapsulation ppp
dialer pool 1
dialer remote-name *******
dialer string *******
dialer-group 1
no cdp enable
ppp chap hostname ******
ppp chap password 0 *******
router ospf 100
log-adjacency-changes
area 0.0.0.24 authentication
network 23.4.4.1 0.0.0.0 area 0.0.0.24
network 23.24.31.1 0.0.0.0 area 0.0.0.24
ip classless
ip route 0.0.0.0 0.0.0.0 23.3.9.1
ip route 23.200.4.18 255.255.255.255 23.3.9.1
no ip http server
map-class frame-relay data
frame-relay cir 192000
frame-relay bc 192000
frame-relay be 64000
frame-relay mincir 192000
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
snmp-server host *********** private
banner motd toytown ROUTER
line con 0
password
login
line aux 0
line vty 0 4
password
login
end
  • Other Network Infrastructure Subjects
Silver
Re: frame-relay/ip conectivity
the first thing I would do is simplify the config by removing the OSPF authentication , and the ip addresss helper commands , see if you can ping , readd them one at see what line is causing the problem , I think it is going to be the helper command .
I tried your suggestion as below but unfortunatly it hasn't helped. I also checked the Frame-relay status and there are packets going back and forth.
bandwidth 256
ip address 23.4.4.1 255.255.255.128
no cdp enable
Silver
Can you paste in a sh fr pvc from both sides , also what does the config on the ohther end look like , also can you enable cdp to see if you get cdp across the PVC
Hi, The far end is/are 3com NB11's (this is part of the migration project) However as I mentioned above they can ping the interfaces from their end! Why can't I ping from the box itself?
The results of SH FRAME_RELAY PVC, a ping and SH IP INT are given below hope the are of use.
Serial0.16 is up, line protocol is up
Hardware is PowerQUICC Serial
Description: Backup PVC to LM
Internet address is 23.4.4.129/25
MTU 1500 bytes, BW 256 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY IETF
Serial0.17 is up, line protocol is up
Description: Primary link to HQ
Internet address is 23.4.4.1/25
toytown#sh frame-relay pvc
PVC Statistics for interface Serial0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 2 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 16, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0.16
input pkts 274 output pkts 5 in bytes 17109
out bytes 520 dropped pkts 0 in pkts dropped 0
out pkts dropped 0 out bytes dropped 0
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
5 minute input rate 2000 bits/sec, 2 packets/sec
pvc create time 01:29:54, last time pvc status changed 00:02:17
DLCI = 17, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0.17
input pkts 18 output pkts 23 in bytes 1080
out bytes 1960 dropped pkts 0 in pkts dropped 0
out bcast pkts 17 out bcast bytes 1360
pvc create time 01:30:02, last time pvc status changed 00:02:25
ping 23.4.4.1
Sending 5, 100-byte ICMP Echos to 23.4.4.1, timeout is 2 seconds:
*Mar 1 01:31:17.387: IP: s=23.4.4.1 (local), d=23.4.4.1 (Serial0.17), len 100,
sending.
*Mar 1 01:31:19.387: IP: s=23.4.4.1 (local), d=23.4.4.1 (Serial0.17), len 100,
sending.
*Mar 1 01:31:21.387: IP: s=23.4.4.1 (local), d=23.4.4.1 (Serial0.17), len 100,
sending.
*Mar 1 01:31:23.387: IP: s=23.4.4.1 (local), d=23.4.4.1 (Serial0.17), len 100,
sending.
*Mar 1 01:31:25.271: IP: s=23.4.4.1 (local), d=224.0.0.5 (Serial0.17), len 76,
sending broad/multicast
*Mar 1 01:31:25.387: IP: s=23.4.4.1 (local), d=23.4.4.1 (Serial0.17), len 100,
sending.
Success rate is 0 percent (0/5)
sh ip int serial0.17
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.5 224.0.0.6
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is enabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Fast switching turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
Silver
does OSPF form an adjacency ? If it does then you could be hitting a bug , if it does not , the DLCI's could be mapped wrong in the FR cloud. On the remote end did you check to make sure you have the DLCI's/IP addresses applied to the correct interface ?
Ospf is not forming an adjacency, the far end is stuck in init, the 1721 is not doing anything. There is an existing 3com router that this is meant to replace and it works fine. This leads me to believe that the frame cloud is ok. The sh frame-relay pvc answers match what I expect as to lmi dlci etc. I am using the same ip address's etc as the existing router.
Silver
did you try to remove the helper from the nmain interface ?
Bronze
Does the 3com device have any debugs that show it is receiving any packets? Try pinging from the 3com with the cisco disconnected just to see if it is really talking to the cisco.
I did and it didn't change anything.
164
