Frame-relay latency
What are excessive frames on a frame-relay cloud? What does this mean..is it frames that are over the cir? We are experiencing latency over our frame-relay network which the carrier is seeing as 'excessive frames'? Is this a congestion issue on the carriers side?
1 REPLY
Bronze
Re: Frame-relay latency
Assume tht excessive frames imply frames above the guaranteed rate on the PVC...
it could be edge devices on the FR cloud are sending at a rate higher than the guaranteed rate thus leading to congestion in the FR cloud. You could use frame relay traffic shaping to help alleviate this is need be:
http://www.cisco.com/warp/public/125/traffic_shaping_6151.html
248
