08-20-2003 09:20 AM - edited 03-02-2019 09:45 AM
Here is my situation. I have a very simple set up between our corporate HQ and remote shops. A 2611XM at corporate and 1602 out in the field. I have 56k lines wit 16k PVCs at each site and a 768k line at corporate. I have a new site that I cannot get the circuit to come up. AT&T insists it is a CPE problem. I have replaced the router at the remote site 3 times already and changed out all the cables. I even had Bell South replace the dmarc/smart jack. I have no extended dmarc at the site. The 1602 router gives me a up/down on the serial port. I have verified lmi-type and DLCI with AT&T. Below are the configs from the 2 routers. Any help would be great...this one is killing me!
2611XM Corporate
service timestamps debug datetime show-timezone
service timestamps log datetime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname Natick
enable secret
enable password
ip subnet-zero
no ip source-route
call rsvp-sync
interface FastEthernet0/0
ip address 10.10.2.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 192 native
ip address 192.168.2.1 255.255.255.0
interface Serial0/0
bandwidth 768
no ip address
encapsulation frame-relay
service-module t1 timeslots 1-12
frame-relay lmi-type ansi
interface Serial0/0.73 point-to-point
description Frame-Relay PVC To Marietta, GA
ip address 10.10.73.254 255.255.255.0
frame-relay interface-dlci 490
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface FastEthernet0/1.1
encapsulation dot1Q 10
ip address 10.0.2.1 255.255.255.0
ip helper-address 192.168.2.25
interface Serial1/0
bandwidth 384
no ip address
no fair-queue
service-module t1 timeslots 1-6
interface Serial1/0.1 point-to-point
description Frame-Relay PVC To Westchester Mirror
ip address 10.10.3.254 255.255.255.0
frame-relay interface-dlci 475
router eigrp 1
network 10.0.0.0
network 172.0.0.0
network 192.168.2.0
network 192.168.254.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
1602 Remote
hostname Marietta
enable secret
enable password
ip subnet-zero
interface Ethernet0
description Marietta Ethernet Network
ip address 10.0.73.1 255.255.255.0
no ip directed-broadcast
interface Serial0
no ip address
no fair-queue
service-module 56k clock source line
service-module 56k network-type dds
interface Serial0.1 point-to-point
description Frame Relay PVC to Natick
ip address 10.10.73.253 255.255.255.0
frame-relay interface-dlci 875
router eigrp 1
passive-interface Ethernet0
network 10.0.0.0
no ip classless
ip route 0.0.0.0 0.0.0.0 10.10.73.254
line con 0
session-timeout 25
exec-timeout 25 0
password
login
transport input none
flowcontrol hardware
line vty 0 4
session-timeout 25
exec-timeout 25 0
password
login
end
08-20-2003 09:33 AM
Just to add. AT&T can loop the smartjack, but not my CSU.
08-20-2003 10:53 AM
What is the status on your HQ router ?
You should try your frame relay encap and frame-relay interfacedlci commands with the ietf keyword at the end.
If that does not do it, you might want to debug the lmi and check the lmi exchange between your remote router and the AT&T switch.
08-20-2003 11:51 AM
The status on the router at corporate is up/down
I will try the ietf keyword
Thanks!
08-20-2003 11:56 AM
The serivice provider will not be able to loop you without the command 'service-module T1 FDL both' configured .
Can you paste in a sh int serial x from both sides and a sh frame-relay pvc
08-20-2003 01:30 PM
are you getting link on the local loops? (sho int) do see the pvcs? (sho fram pvc) Is there any LMI communication/ (sh fra lmi)
08-21-2003 03:05 AM
Below is a sho int s0/0 and for the sub interface s0/0.73 for the HQ router (2611)
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
MTU 1500 bytes, BW 768 Kbit, DLY 20000 usec,
reliability 255/255, txload 53/255, rxload 28/255
Encapsulation FRAME-RELAY, loopback not set
Keepalive set (10 sec)
LMI enq sent 66664, LMI stat recvd 66663, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 8945250/230426, interface broadc
asts 8108277
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w0d
Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 6276
Queueing strategy: weighted fair
Output queue: 0/1000/64/6170 (size/max total/threshold/drops)
Conversations 0/101/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 576 kilobits/sec
5 minute input rate 87000 bits/sec, 65 packets/sec
5 minute output rate 161000 bits/sec, 66 packets/sec
46369878 packets input, 443908465 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
49358856 packets output, 831865153 bytes, 0 underruns
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/0.73 is down, line protocol is down
Description: Frame-Relay PVC To Marietta, GA
Internet address is 10.10.73.254/24
reliability 255/255, txload 54/255, rxload 28/255
This is the sh int s0 for the remote site router (1602)
Serial0 is up, line protocol is down
Hardware is QUICC Serial (with onboard CSU/DSU)
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 155/255, txload 1/255, rxload 1/255
Encapsulation FRAME-RELAY, loopback not set, keepalive set (10 sec)
LMI enq sent 6669, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down
Broadcast queue 0/64, broadcasts sent/dropped 7/0, interface broadcasts 6
Last input never, output 00:00:07, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 106 giants, 0 throttles
22163767 input errors, 4017951 CRC, 10090593 frame, 0 overrun, 0 ignored, 8
055223 abort
6676 packets output, 94043 bytes, 0 underruns
0 output errors, 0 collisions, 2215 interface resets
0 carrier transitions
08-21-2003 03:07 AM
Here is the sho frame pvc for the remote site router
PVC Statistics for interface Serial0 (Frame Relay DTE)
DLCI = 875, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0.1
input pkts 0 output pkts 7 in bytes 0
out bytes 669 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 7 out bcast bytes 669
pvc create time 18:32:38, last time pvc status changed 18:32:04
08-21-2003 03:40 AM
Why do you have these commands configured ?
were they specified by the service provider ?
08-21-2003 03:46 AM
Yes, they were specified by the service provider. I inhereted all of this a short time ago and it's one of those things that was specified at one time before I came along and since all of our 55 or so sites are exactly the same type of connection, it has always been in there.
08-21-2003 03:58 AM
Ok
Is there an extended demarc ?
If there is you need to plug your router in to the demarc. If the circuit comes up up then you have a problem on the extended demarc. If it does not then make a loopback plug ,
http://www.juniper.net/techpubs/software/nog/nog-interfaces/html/fe-ge-loopback25.html
if you can not make a plug or have no one at the site then do this
then change the encap on your serial interface to hdlc and assing it an ip address(does not matter what the ip address is you are just using it for testing , this will allow you to see loops by the provider. Have the provider go to the closest DAX and give you a loop , your interface should go up up (looped),if it does not then there is a provider problem. If it does come up up (looped) and you can ping yourself have the provider move back one test point and do the same , keep repeating this test until you can not ping yourself , when this happens , this is where the problem lies .
08-21-2003 04:02 AM
Ok, cool I'll try that. Thanks!
BTW, there is no extended demarc
08-21-2003 05:36 AM
assuming you have the 56k csu/dsu the command to allow loopback is "service-module 56k remote-loopback" but your problems look like they will prevent that from working anyway.
Have you verified the speed with the carrier? Try 64k or auto with the command "service-module 56k clock rate [64|auto]"
