01-29-2004 10:27 AM - edited 03-02-2019 01:14 PM
On a remote site I have a serial connection & one Ethernet connection (256K - Cisco 1720 router) with point-to-point PVC's back to the corporate office.
I need to create two separate LANS & load balance the connections. My question is, can I upgrade the router to support two Ethernet connections & load balance the serial connection.
01-29-2004 07:01 PM
You mentioned "PVC's"...is there more than 1 ? How many ? Are they costed the same (i.e. a routing protocol would see them as equal cost paths to the corporate HQs) ?
If you need to support 2 LANs you may be able to just put a secodary IP on the single Ethernet. This will depend on your Layer 2 design (how many switches) and how many users (don't want to overload the LAN with broadcasts).
Michael J. Morris
CCIE #11733, MCSE
01-30-2004 04:47 AM
I have two PVC's back to the corporate office ( two different provider T's back at the corporate office, the second PVC at the remote office is not being used, only used if the first PVC goes down).
I have a political war going on at the remote office. Half of the office are corporate employees, half are non-employees. Each group complaining about bandwidth usage. I want to bump up the bandwidth and not have to go through the process of ordering a second circuit for that office.
I hope that answers your questions.
01-30-2004 06:11 AM
On the primary PVC....what is the CIR ? Is it a full T-1 PVC....i.e CIR = 1544k = T-1 ?
01-30-2004 06:37 AM
The CIR is 256, see remote & Frame router config below. I also have another idea. Can I upgrade the router so that I can support two Ethernet connections and have each ethernet port use different timeslots.
REMOTE CONFIG
interface Serial0
bandwidth 256
no ip address
no ip redirects
no ip unreachables
encapsulation frame-relay
priority-group 2
service-module t1 timeslots 1-4
frame-relay lmi-type ansi
FRAME ROUTER CONFIG
map-class frame-relay 256
frame-relay cir 256000
frame-relay bc 32000
frame-relay be 0
frame-relay mincir 256000
01-30-2004 12:46 PM
No, you don't have a mutli-channel controller in this router, so you wont be able to break up the channels.
You can have another PVC put in and then make routing changes to ensure employee traffic from the head-end goes over PVC1 and non-employee traffic from the head-end goes over PVC2. That can depend a lot on your routing protocol (EIGRP is good at this).
Another problem will be determining the source of the traffic when it comes in the Ethernet. Here you'll have to do policy routing. If traffic is from employees, policy-route on PVC1...if traffic is from non-employees, policy route on PVC2.
In actuality, I think the easist way is to apply some QoS...find out what traffic is most important and make that the priority. However, you have a 256k circuit...if your using almost all of that, you need a BW upgrade, not QoS.
Good luck.
02-03-2004 09:52 PM
Just an idea
Remote Router
int FastEthernet0
ip address 172.16.0.1 255.255.255.128
ip address 172.16.0.129 255.255.255.128 secondary
int Serial0
interface s0.1 point-to-point
ip address 172.16.1.254 255.255.255.252
fram-relay interface-dlci 100
ip address 172.16.1.2 255.255.255.252
fram-relay interface-dlci 200
access-list 1 permit ip 172.16.0.0 0.0.0.126
access-list 2 permit ip 172.16.0.128 0.0.0.126
Then
interface FastEthernet0
ip policy route-map employ-policy
route-map employ-policy permit 10
match ip address 1
set ip next-hop 172.16.1.253
route-map employ-policy permit 20
match ip address 2
set ip next-hop 172.16.1.1
