Frame Relay Map class
When you configure a map class with:
map-class frame-relay 28K
no frame-relay adaptive-shaping
frame-relay cir 56000
frame-relay mincir 28000
What triggers the mincir to take affect if "no frame-relay adaptive-shaping" is configured?
1 REPLY
Anonymous
N/A
Re: Frame Relay Map class
The minimum cir is only used to
calculate the tc value used for frame clocking and token interval.
With no adaptive-shaping, no trottle down is done and hence
frame are only allowed to CIR specified and the overlap frames
are queued or droped if queue is full.
If you'll like to react to fecn and becn and react to them adaptively.
Then I suggest you enable adaptive shaping. Both
supports adaptive and non-adaptive shaping. The default is to disable
it as its assumed the map-class is for voice traffic.
100
