Frame-relay multipoint
Hi, there
If my router is enabled with IARP, do I still have to use the command
frame-relay interface-dlci 325
(where 325 is the local DLCI of my router)
to associate my serial interface with the dlci number 325 in a multipoint configuration environment?
1 REPLY
Re: Frame-relay multipoint
Yes, you do
87
