Community Member
frame relay ppp or multipoint
which is the best to do, either way I gather to need to have 2 dlci's from your isp ? so in which case would it just be better to use seperate point to point interfaces rather than 1 multipoint ?
1 REPLY
Re: frame relay ppp or multipoint
Carl,
Point to point interfaces can be easier to use when dealing with routing protocols and troubleshooting.
All in all it kind of depends on personal preference and if you have to follow any specific mandates for your wan links. I like using point to point interfaces because we use monitoring tools for bandwidth on many of my customer sites which helps them decide which sites need to be bumped up for bandwidth.
Patrick
106
