08-13-2002 02:36 AM - edited 03-02-2019 12:39 AM
Hi.
I'm try to set up a frame relay network with two 2610 with one serial device.
I have one direct link over a v35+dce that connect the two serial.
My configuRATION WAS PRETTY SIMPLE:
interface serial0/0
no ip address
encapsulation frame-relay
frame-relay lmi-type cisco
interface serial0/0.1 point-to-point
ip address xxxxx
frame relay interface-dlci 1111 ietf
On router 2 the dlci was 1112.
With sh int s0/0 the line was up and protocol was down
With sh int s0/0.1 the line was down and the protocol was down
Why this?
I'm missing something?
Best Regards.
08-13-2002 04:07 AM
hi giuliano,
i'm just configuring my routers to help you solve your problem. first of all
my router doesn't accept the dlci 1111.
I'm missing the frame-relay switch between your two routers.
regards
sascha
08-13-2002 04:08 AM
hi giuliano,
regards
sascha
08-14-2002 03:30 AM
You need to enable frame-relay switching on both routers, also
configure the dce serial interface as DCE interface with comand frame-relay
intf-type DCE and dte interface frame-relay intf-type DTE.
08-14-2002 04:27 AM
Write "no keepalive" on the 2 router FR main interface. I think this will solve your problem.
