FRAME-RELAY PROTOCOL DOWN.
giuliano
Hi.
I'm try to set up a frame relay network with two 2610 with one serial device.
I have one direct link over a v35+dce that connect the two serial.
My configuRATION WAS PRETTY SIMPLE:
interface serial0/0
no ip address
encapsulation frame-relay
frame-relay lmi-type cisco
interface serial0/0.1 point-to-point
ip address xxxxx
frame relay interface-dlci 1111 ietf
On router 2 the dlci was 1112.
With sh int s0/0 the line was up and protocol was down
With sh int s0/0.1 the line was down and the protocol was down
Why this?
I'm missing something?
Best Regards.
s.lemberg
hi giuliano,
i'm just configuring my routers to help you solve your problem. first of all
my router doesn't accept the dlci 1111.
I'm missing the frame-relay switch between your two routers.
regards
sascha
s.lemberg
hi giuliano,
regards
sascha
ccobtn
You need to enable frame-relay switching on both routers, also
configure the dce serial interface as DCE interface with comand frame-relay
intf-type DCE and dte interface frame-relay intf-type DTE.
mazhar71
Write "no keepalive" on the 2 router FR main interface. I think this will solve your problem.
