frame-relay pvc bandwidth over 2Mbps
Hi!
Is it possible to configure a FR PVC with bandwidth more than 2Mbps (for example 4, or 6Mbps) on a Cisco3745 with a NM-1T3/E3 module?
thanks in advance:
Peter
1 REPLY
Silver
Re: frame-relay pvc bandwidth over 2Mbps
You can configure the frame-relay PVC higher than 2Mbps for HSSI interface provided your service provider supports it .
241
