Webcast-Catalyst9k
Frame relay PVC problem
My customer using frame relay connection between Hong kong & Indonesia
The problem is the DLCI 200 & 400 usaged are unused but pvc active and for DLCI 600 ( both side) usaged are local but deleted.
Network provider set the DLCI as 200 and 400.
can some one tell me why MY customer getting the DLCI usaged as unused.
Hong Kong FRAME PVC RESULT
PVC Statistics for interface Serial1/2 (Frame Relay DTE)
Active Inactive Deleted Static
Local 0 0 1 0
Switched 0 0 0 0
Unused 1 0 0 0
DLCI = 200, DLCI USAGE = UNUSED, PVC STATUS = ACTIVE, INTERFACE = Serial1/2
input pkts 120 output pkts 60 in bytes 3840
out bytes 1800 dropped pkts 1 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 60 out bcast bytes 1800 Num Pkts Switched 0
DLCI = 600, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial1/2
input pkts 0 output pkts 0 in bytes 0
out bytes 0 dropped pkts 0 in FECN pkts 0
out bcast pkts 0 out bcast bytes 0
INDO FRAME PVC RESULT
PVC Statistics for interface Serial0/1 (Frame Relay DTE)
Local 0 1 0 0
Switched 0 0 0 0
Unused 1 0 0 0
DLCI = 600, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/1
input pkts 1721 output pkts 2552 in bytes 167840
out bytes 265349 dropped pkts 2 in FECN pkts 0
in BECN pkts 8 out FECN pkts 0 out BECN pkts 0
in DE pkts 162 out DE pkts 0
out bcast pkts 2 out bcast bytes 149
pvc create time 4d00h, last time pvc status changed 2d01h
DLCI = 400, DLCI USAGE = UNUSED, PVC STATUS = ACTIVE, INTERFACE = Serial0/1
input pkts 131 output pkts 66 in bytes 4190
out bytes 2244 dropped pkts 0 in FECN pkts 0
out bcast pkts 66 out bcast bytes 2244 Num Pkts Switched 0
Bronze
Re: Frame relay PVC problem
Hi S12083,
DLCI USAGE=UNUSED means that the provider has configured its switch to use this DLCI but your router is not configured to use it.
DLCI USAGE=LOCAL, STATUS=DELETED means the inverse; your router uses it (USAGE=LOCAL) but the switch does not know it.
So if I understand correctly, you are not using the DLCI's that your provider gave you and instead you chose your own. This will not work, you have to use the same DLCI as the provider.
Change the DLCI in Hong Kong to 200 and in Indonesia to 400 and it should work.
hth
Herbert
That what I had informed to my customer but they want a third party to clarify it.
Thank for your help
204
