Community Member
Frame Relay PVC through another router
I have two routers connected to each other via a 2mb leased line. I need to build a FR PVC between these two routers over the leased line - any idea how I do this? I know how to do it back-to-back and I've seen the doc on CCO, it's just that this isn't back-to-back, so I presume I have to do something different.
Also, once I have this working, I have another router connected to one of the routers above via a DCE/DTE X.21 cable. I need to build a FR PVC from this router through the directly connected router to then terminate on the remote router at the other end of the leased line. I don't know how to do this, the PVC needs to run in parallel with the first one.
All routers are of course Cisco.
Any help greatly appreciated.
Community Member
Re: Frame Relay PVC through another router
I was thinking of frame-relay switching, which can be configured on a cisco router as follow:
conf t
interface serial 0
encapsulation frame-relay
clock-rate 64000
frame-relay intf-type DCE
frame-relay route 100 interface serial 1 101
! DLCI 100 incoming, out S1 DLCI 101
Lode
you can use this config to make the "middle" router to work as FR switch:
conf t
interface Serial0
no ip address
frame-relay intf-type dce
frame-relay route 16 interface Serial1 16
interface Serial1
no ip address
frame-relay route 16 interface Serial0 16
Milan
93
