Frame Relay question
Hello.
I am trying to set up a test lab for frame relay. i have two 2620 routers plugged into one 2503 router with 2 serial ports. The 2503 is acting as the DCE for each. I am having two problems. I am unable to ping the router on the far interface of the 2503.(from the router on the s0 to the router on the s1). What do I need to do to enable this? Also I seem to be loosing packets somewhere, as my pings are only about 60% successful. Any advice would be great. Thanks in advance
Will
Re: Frame Relay question
Make sure all the encapsulations are right.
Anonymous
N/A
all are frame relay
Anonymous
N/A
I have also tried to add a frame realy map and I get the following error
COl_2503_01(config-if)#frame-relay route 100 interface s1 200
can't route on this dlci as a map exists
Bronze
The response that you got when you entered the frame-relay route command seems to indicate that you already have a map on the interface. Go through your configuration and remove any frame-relay map statements that you find.
Good Luck,
Mark
252
