Frame relay question
This is a strange question I know, but I think I have seen this written some where.
Is it possible to have frame relay PVCs over an Ethernet connection. I dont know what this would be called, frame relay encapsulation over Ethernet ??.
Maybe i'm getting mixed up with PPP over Ethernet, please correct me if i'm wrong.
(PS, I dont really want to use GRE tunneling over Ethernet)
1 REPLY
Re: Frame relay question
The feature you are refering to is part of the frame relay switch feature set. It allows a PVC to be transported over IP between Routers with frame relay switching enabled.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/wan_c/wcdfrely.htm#xtocid22185103
Configuration for Router A
frame-relay switching
interface ethernet0
ip address 108.131.123.231 255.255.255.0
interface ethernet1
ip address 131.108.5.231 255.255.255.0
interface serial0
no ip address
shutdown : Interfaces not in use may be shut down; shutdown is not required.
interface serial1
ip address 131.108.222.231 255.255.255.0
encapsulation frame-relay
frame-relay map ip 131.108.222.4 400 broadcast
frame-relay route 100 interface Tunnel1 200
interface tunnel1
tunnel source Ethernet0
tunnel destination 150.150.150.123
Configuration for Router D
interface ethernet0
ip address 131.108.231.123 255.255.255.0
interface ethernet1
ip address 131.108.6.123 255.255.255.0
interface serial0
ip address 150.150.150.123 255.255.255.0
encapsulation ppp
interface tunnel1
tunnel source Serial0
tunnel destination 108.131.123.231
interface serial1
ip address 131.108.7.123 255.255.255.0
frame-relay intf-type dce
frame-relay route 300 interface Tunnel1 200
96
