Webcast-Catalyst9k
Frame Relay Simulation
I have a customer who is rolling out about a 115 new 2650XM routers.
These routers will have the built in CSU/DSU in slot 0 and ISDN Bri in slot 1.
They would like the frame relay operation tested. I was told about back to back frame simulation using the serial ports. How would you go about doing this with the csu/dus built in.
Any ideas on how to do this??
1 REPLY
Re: Frame Relay Simulation
YES..you can configure one of the cisco router to act as "Frame-relay switch"
You can connect the routers using serial interfaces and create frame relay network. Pl. visit following link for that
http://www.cisco.com/warp/public/125/fr_switching.html
104
