Webcast-Catalyst9k
frame-relay :subinterfaces and channelized E1
I want to built a network based on 'Hub and Spoke' network design., the main office has 3661 with CE1 Module,i have 15 branch offices, so i used CE1,each
branch office have 128K access speed, the WAN LINK
is frame-relay.
but some one said : using subinterfaces can do it,
so i can order more cheap module, for example:
the module with WIC-1T.
now i am wondering:
1 when (What condition) should i use CE1?
2 the two solution above can do the job well ?
3 dose CE1 work in frame-relay?
thank you very much
Re: frame-relay :subinterfaces and channelized E1
Things to consider
1) the CE1 interface is usually ISDN, find out from the TELCO what service they are providing.
eg 2MB frame relay, or 30 channel ISDN.
if it is standard Frame then you will need a Wic-1T.
2) what service is being provided to the remote branches, again is it ISDN or Frame relay?
3) what routers do you have at the remote sites?
i understand that:CE1 can be used for TDM network or ISDN ,right ?, if ISDN, i have 3 branches, so i can supply 640KBPS for each branch? if so what module my branch router(2621) use? what cable for it?
another question:
if my main office service is frame relay, i use the
WIC-1T,and use subinterface ,but my branches is ISDN
service, How can i do ?
if each branch is going to be 640k, then you would need an ISDN primary interface ..
What services are being provided by the Telco?
tell what you have at each location.eg bandwidth etc
once you know what is supplied we can then work out what interfaces are required.
scenario 1
my main office
hub router:3661
teleco service:Frame-relay
bandwidth 2M
my branche office 3 sites
router 2621
teleco servive: ISDN
i want make Hub spoke network
each site bandwidth: 640k
Can you design this network according to different teleco services.and please show me the modules for
each router.
scenario 2
my main office
hub router:3661
teleco service:ISDN
bandwidth 2M
router 2621
Can you design this network according to SAME teleco services.and please show me the modules for
each router.
THANK YOU IN ADVANCE
173
