Webcast-Catalyst9k
frame relay switch
can anyone tell me how to set up a frame relay switch on my 1700 roouter with 2 serial connections, I want this to act like my isp. I believe this can be done, it is for testing in my home lab
thanks
Carlos
1 REPLY
Re: frame relay switch
Hi Carl,
Yes you can cofigure router as a frame relay switch.
Check this link
http://www.cisco.com/warp/public/125/fr_switching.pdf
Just check the config for router Americas in that link and you will get to know how to switch the dlci.
To get a complete know how about Frame Relay have a look at this link
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
HTH, if yes please rate the post.
Ankur
96
