Frame-Relay Switching and Tunnel
I'm have 2 Cisco 2501, and I need configure them as Frame-Relay Switching, but this model has only 2 Serial interfaces, so I get some configuration examples that explain how configure Frame-Relay switching on a Tunnel using the Ethernet Interface, but some commands of this configuration are inexistent... here the command:
frame-relay route 113 interface Tunnel0 311
My IOS version is 12.0(6), on this version I can't use "frame-relay route XXX inteface TUNNEL XXX", the interface Tunnel is not accept, if I use help (?), the IOS displays only interface Serial option...
can you help me?
Jefferson
CCNA / CCNP / CCAI
Re: Frame-Relay Switching and Tunnel
You need Enterprise Edition IOS. To accomodate this IOS, You need 16 MB of RAM and 16 MB of flash, at least for IOS ver. 12.1
Giedrius
Thanks Giedrius...
your help is very useful!!!
110
