Webcast-Catalyst9k
frame-relay switching with policing and "connect" command
hi,
i have the task to switch an fr-pvc on my 3640 router.
the problem is that i have to police the incomming pvc (from the customer) so that it does not exceed a certain cir.
so i read about "frame-relay policing" and that i have to define the fr-route with the "connect" command.
no problem (i thought so) !
the problem is that i switch this pvc in an gre-tunnel (ip) and it is NOT possible
that i do a connect-command with a tunnel interface.
br-grztr1(config)#connect one ?
Dialer Dialer interface
MFR Multilink Frame Relay bundle interface
Serial Serial
Virtual-FrameRelay Virtual Frame Relay interface
vc-group Frame Relay VC group (FRF.5 only)
how can i do this - or is cisco able to connect the pvc to a tunnelint. in future realeases ???
thanks for an answer !
Re: frame-relay switching with policing and "connect" command
As to connecting the frame pvc to the gre-tunnel I would just be guesing. To actually switch the pvc you would have to turn on frame relay switching and map the dlci to an other interface ( your tunnel?) and dlci. to police it you could use the frame relay map and define a map class to set cir, be ect.
Can you police the pvc on the frame interface and bridge to your tunnel?
hi,
thanks for answer, but:
the problem is that i can´t do a shapping incomming on the serial on which i have the customer connected.
here is the config on the interface:
interface Serial2/0
description Verbdg. zum FR-Testrouter A
bandwidth 256
no ip address
rate-limit input 128000 2000 2000 conform-action transmit exceed-action drop
encapsulation frame-relay IETF
load-interval 30
no fair-queue
frame-relay lmi-type q933a
frame-relay intf-type dce
frame-relay route 116 interface Tunnel99 116
Fact is that this router does no shapping or rate-limiting on this interface - i don´t know why-perhaps because the traffic is pure layer2 traffic for this router.
my idea was to rate-limit the incomming l2-fr-traffic before forwarding this traffic to the tunnel with the "frame-relay route" command.
but as i said - it does not work.
in the interfaceconfig above i did it with the "rate-limit" comand-but i also tried with traffioc shapping incoming.
the frame-relay class was:
map-class frame-relay police_128k
frame-relay cir in 122000
frame-relay bc 12200
frame-relay be 0
butz it also did not work-perhaps because of the same reason:
for the router this traffic is "only" layer2 traffic !
any idea ??
202
