Community Member
Frame-relay switching
Hi, I am trying to create a frame-relay cloud by using 2 routers (FRS1 and FRS2)
I am not able to get frame-relay switching to work over the cloud.
I have 2 routers connected one to FRS1 and another to FRS2).
FRS1
_____
interface Tunnel12
no ip address
tunnel source Serial0
tunnel destination 12.12.12.2
interface Serial0
ip address 12.12.12.1 255.255.255.0
interface Serial1
no ip address
encapsulation frame-relay
frame-relay intf-type dce
frame-relay route 104 interface Tunnel12 401
FRS2
interface Serial0
ip address 23.23.23.2 255.255.255.0
interface Serial1
no ip address
clockrate 2000000
frame-relay route 401 interface Tunnel12 104
FRS2#sh frame pvc
PVC Statistics for interface Serial1 (Frame Relay DCE)
DLCI = 401, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial1
What is it that I am missing?
Bronze
Re: Frame-relay switching
Note that on FRS2, Serial1, the PVC is inactive. This would lead me to suspect the FR connection from FRS2 to the FR remote device, and not FRS1 or the tunnel. The config looks OK, but your PVCs have to be active before you worry about switching anything.
This may help some, too:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fwan_c/wcffrely.htm#xtocid55
cwy
Community Member
How about the sho interface result?
126
