Community Member
frame relay T1
hello,
will a frame-relay T1 push 1.5M out and 1.5M in for a total of 3M.
thanks,
Bronze
Re: frame relay T1
Yes, provided that the carrier allows full capacity on the T1. T1 speeds are bi-directional, meaning 1.5M in each direction.
Mark
Community Member
Re: frame relay T1
I guess I should have specified the Cisco T1 WIC. Will they do 1.5M in and 1.5M out simultaneously?
Community Member
Re: frame relay T1
Keep in mind that you will never get completely to 1.5, but yes, being bi-directional, you can get close to 1.5 in each direction.
210
