Frame Relay to ATM Network Interworking Bridging Configuration.
I am looking for a Bridging configuration between two sites.On central site ATM
with sub interfaces and on the end points Frame-relay . The bridge is needed to transfer LAT over the Interworking WAN .Can anybody help me with configuration?
Attached are configuration of the two ends. this is no working.
================Central Site =========================
interface FastEthernet0/0
description **** Connection to LAN ***
ip address xxxxxxx
bridge-group 1
interface ATM1/0
no ip address
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
interface ATM1/0.32 point-to-point
bandwidth 128
ip address xxxxxxx
no ip route-cache
no ip mroute-cache
pvc 0/32
ubr 157
bridge-group 1
ibridge 1 protocol dec
==================end point=============================
interface Ethernet0
ip address xxxxxxx
bridge-group 1
interface Serial0
ip address xxxxxxx
encapsulation frame-relay IETF
keepalive 11
no fair-queue
frame-relay interface-dlci 16
frame-relay lmi-type ansi
frame-relay map bridge 16 broadcast
bridge-group 1
1 REPLY
Anonymous
N/A
Re: Frame Relay to ATM Network Interworking Bridging Configurati
Without the debug output, it will be difficult to find out where exactly the problem has occured.
But for making sure that the configurations are perfect, you can go through the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fibm_c/bcfpart1/bcftb.htm
112
