Frame Relay Traffic Shaping and QOS
Is anyone out there using LLQ with Frame-Relay and Traffic Shaping? If so, I have a question. Since FRTF shapes your PVCs to control congestion, does that not somewhat defeat the mechanism in which to trigger QOS?
I have been trying to "Validate" that QOS is working with FRTF and CBWFQ and in order to do that, the first thing I want to see is FECNs and BECNs, but with FRTF turned on, they arnt there when I try to flood the interface(sh frame-relay pvc) however, the rudamentary testing appears that CBWFQ is dropping/matching packets...so is it working? Or isnt it?
Here is the relevant part of the config
class-map match-any Gold
match access-group 151
class-map match-any Bronze
match access-group 150
policy-map Test
class Gold
bandwidth 30
class Bronze
bandwidth 10
interface serial0
no fair-queue
frame-relay traffic-shaping
interface serial0/0.1
bandwidth 128
frame-relay class FRAMECLASS
frame-relay interface dlci 111
map-class frame-relay FRAMECLASS
frame-relay traffic-rate 128000 256000
no frame-relay adaptive shaping
frame-relay mincir 128000
service-policy output Test
access-list 151 permit icmp any any
access-list 150 permit tcp any any eq telnet
Remote> sh service-policy int
Serial 0/0.1: DLCI 111 -
Service-policy output: QOS
Class-map: Bronze (match-any)
249819 packets, 184093742 bytes
5 minute offered rate 196000 bytes, drop rate 97000 bps
0 packets, 0 bytes
5 min rate 149000 bps
Match: access-group 150
5 min rate 196000 bps
Weighted Fair Queueing
Output Queue: Conversation 25
Bandwidth 10 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 14563/11042224
(depth/total drops/no buffer-drops) 64/7489/0
Class-map: Gold (match-any)
756 packets, 36288 bytes
5 minute offered rate 0bps, drop rate 0 bps
Match: access-group 151
5 minute offered rate 0 bps
Remote> sh frame-relay pvc 505
DLCI 111, DLCI USAGE= LOCAL, PVC STATUS=ACTIVE, INTERFACE S0/0.1
input pkts 396725 output pkts 294605 in bytes 2362828272
out bytes 747220333 dropped pkts 0 in pkts dropped 0
out pkts dropped 14538 out bytes dropped 10061844
late-dropped out pkts 14538 late-dropped out bytes 1061844
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 5128 out bcast bytes 663775
pvc create time 22:34:20, last time pvc status changed 22:35:29
If I remove FRTF, I get FECNS and BECNS but i need it to shape!...any ideas?
This is a 128kPVC/256k port
Afilandro
1 REPLY
Silver
Re: Frame Relay Traffic Shaping and QOS
When you configure FRTS what happens is the router queues up the traffic and 'shapes' it to the speed of the PVC . in other words it will send your traffic out at a steady rate with no bursting. This is the reason you will not get FECN & BECN.
With CBWFQ you are guarenteeing bandwidth for the classes you define 30K for ping and 10K for telnet
105
