frame relay traffic shaping
admin_2
Level 3
Level 3
Hello. I have a frame-relay map-class set up on my DLCI for 128K but when I run the command show traffic-shape it shows that the target rate is 56000 what would be causing this?
Will
mchin345
Level 6
Level 6
Not enough information to answer this question, refer the following URL and verify your configuration
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#23472
gscholz
Check your naming convention for the map class
The map and the class names must match
The map class name possibly doesn't exist that you are using under the sub-interface
note: the map -class name is case sensitive
