frame relay traffic shaping
If we have 'frame-relay traffic-shaping' enabled on the interface, but no map-class configured, will this default to 56K CIR?
thanks,
1 ACCEPTED SOLUTION
Re: frame relay traffic shaping
Frame-relay traffic shaping is enabled on the main interface, and it applies to all DLCIs under that interface. We cannot enable traffic shaping only for a particular DLCI or subinterface under the main interface. If a certain DLCI has no map class attached to it, and traffic shaping is enabled on the main interface, the DLCI is assigned a default map-class with CIR = 56000.
Yes!
If you have a CCO login, look this link:
http://www.cisco.com/warp/customer/125/traffic_shaping_6151.html
109
