02-07-2002 11:04 AM - edited 03-01-2019 08:23 PM
We have a 256K WAN link that appears to be slow. As a test we sent a 8mb file from end-to-end which took 7 minutes. We tried different times of the day and it stayed around 7 minutes. I calculated that it should take about 1 minute. Stats from AT&T do not show over-utilization at either end. Are my calculations correct?
02-09-2002 05:20 PM
yes.. 8MB file in 7 minutes is great on a 256k line.
perhaps you should run mrtg on the router closest
to you to determine real bandwidth / throughput and
your utilization of the link.
see www.mrtg.org
02-11-2002 11:28 AM
Hmmm slow, maybe not. A 8MB (byte) file is 64,000,000 bits, or 64Mb (bits). 64Mb going across a 256Kbs link, in a perfect world with no overhead would take 250 seconds or 4.1 minutes. Well with packet/frame overhead, OS overhead, I/O on the computer and disk read/writes, a 7 minute download time really is great.
When you read a file size off a hard drive, it's usually in bytes (usually in 8 bit words).
02-12-2002 05:22 AM
Your calculations look correct and I don't know how I came up with 1 minute. Thanks.
02-12-2002 06:20 AM
We tried another transfer using a 1.8mb file. It took 5 minutes 15 seconds. In a perfect world I figured it would take 57 seconds. We then tried another transfer on a 973kb file and it took 2 minutes 26 seconds (perfect world: 30 seconds). It appears the transfer time is 5 times the perfect world transfer time. Is this normal overhead on transfers?
