Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Frame Relay WAN Slowness
We have a 256K WAN link that appears to be slow. As a test we sent a 8mb file from end-to-end which took 7 minutes. We tried different times of the day and it stayed around 7 minutes. I calculated that it should take about 1 minute. Stats from AT&T do not show over-utilization at either end. Are my calculations correct?
noc
Re: Frame Relay WAN Slowness
yes.. 8MB file in 7 minutes is great on a 256k line.
perhaps you should run mrtg on the router closest
to you to determine real bandwidth / throughput and
your utilization of the link.
see www.mrtg.org
Hmmm slow, maybe not. A 8MB (byte) file is 64,000,000 bits, or 64Mb (bits). 64Mb going across a 256Kbs link, in a perfect world with no overhead would take 250 seconds or 4.1 minutes. Well with packet/frame overhead, OS overhead, I/O on the computer and disk read/writes, a 7 minute download time really is great.
When you read a file size off a hard drive, it's usually in bytes (usually in 8 bit words).
Your calculations look correct and I don't know how I came up with 1 minute. Thanks.
We tried another transfer using a 1.8mb file. It took 5 minutes 15 seconds. In a perfect world I figured it would take 57 seconds. We then tried another transfer on a 973kb file and it took 2 minutes 26 seconds (perfect world: 30 seconds). It appears the transfer time is 5 times the perfect world transfer time. Is this normal overhead on transfers?
144
