01-15-2003 08:50 AM - edited 03-02-2019 04:13 AM
Currently I am working on project for school. In this project I have create a frame relay network with ISDN as backup with a 1700 (server) and a 2500 (client) router. I have frame relay up and running but the ISDN doesn't work.
If I disconnect the frame relay the ISDN kicks in. The routers say that they are connected to each other but there is no data transfer what so ever over ISDN. And pinging doesn't work. This is also my first time I worked with a Cisco router. So I would really apriciate any help from someone. I'll post the configs of the routers.
Server (1700):
Building configuration...
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname kleinerouter
username groterouter password 0 isdn
memory-size iomem 25
ip subnet-zero
isdn switch-type basic-ni
interface 172.19.0.0 255..255.255.0
interface Serial0
backup delay 10 30
backup interface Dialer1
no ip address
encapsulation frame-relay
no keepalive
shutdown
no fair-queue
interface Serial0.100 point-to-point
ip address 192.0.0.6 255.255.255.0
frame-relay interface-dlci 100
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 10
no ip route-cache
load-interval 30
no keepalive
shutdown
ppp authentication chap
interface FastEthernet0
ip address 124.0.0.6 255.255.255.252
shutdown
speed auto
interface Dialer1
ip address 142.0.0.6 255.255.0.0
encapsulation ppp
dialer remote-name groterouter
dialer pool 10
dialer idle-timeout 900
dialer string 3099596
dialer max-call 4096
dialer-group 1
router ospf 10
log-adjacency-changes
network 172.19.0.0 0.0.0.255 area 0
network 124.0.0.0 0.0.0.255 area 0
network 142.0.0.0 0.0.0.255 area 0
network 192.0.0.0 0.0.0.255 area 0
router rip
network 124.0.0.0
network 142.0.0.0
network 192.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 124.0.0.1
no ip http server
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
privilege level 15
transport input none
line aux 0
transport input all
line vty 0 4
exec-timeout 0 0
login
end
Client (2500):
version 12.0
service udp-small-servers
service tcp-small-servers
hostname groterouter
username kleinerouter password 0 isdn
ip subnet-zero
process-max-time 200
interface Loopback0
ip address 10.8.8.1 255.255.255.0
interface Ethernet0
ip address 110.0.0.5 255.255.255.252
no ip directed-broadcast
shutdown
interface Serial0
no ip address
no ip mroute-cache
no keepalive
shutdown
no fair-queue
clockrate 148000
cdp enable
ip address 192.0.0.5 255.255.255.0
interface BRI0
no ip address
encapsulation ppp
dialer pool 20
shutdown
dialer-group 1
interface Dialer1
ip address 142.0.0.5 255.255.0.0
encapsulation ppp
dialer remote-name kleinerouter
dialer pool 20
dialer-group 1
router ospf 10
network 10.8.8.0 0.0.0.255 area 0
network 110.0.0.0 0.0.0.255 area 0
router rip
network 110.0.0.0
network 142.0.0.0
network 192.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.200.17.1
no ip http server
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
01-15-2003 09:43 AM
On a client 2500 router named "groterouter" have a config mistake.
1)Bri0 interface is in shutdown mode..which may not be a issue as you might be testing it.
2)Bri0 should have "dialer pool-member 20" command instead of "dialer pool 20".
3)ISDN SPIDs are not configured on any router.
pl. correct that.
Here is the url which has "isdn backup using dialer profiles" explained in detail with sample config and troubleshooting.
http://www.cisco.com/warp/public/129/bri-back-dp.html
So if it still dosen't work, we need following debug on server router kleinerouter when isdn line receives the call.
debug dialer
debug ppp nego
debug ppp auth
debug isdn q931
01-17-2003 04:25 AM
Thx it is working now. But now the problem is that when ISDN backup is up it should disconect if it is idle or there is no datatransfer but now it stays connected.
Configs:
server (1700):
version 12.1
ip subnet-zero
interface Serial0
backup delay 10 30
no ip address
no keepalive
no fair-queue
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
load-interval 30
no keepalive
speed auto
interface Dialer1
encapsulation ppp
dialer pool 10
dialer-group 1
router ospf 10
ip classless
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
transport input all
line vty 0 4
exec-timeout 0 0
login
end
Client (2500):
version 12.0
ip subnet-zero
interface Loopback0
interface Ethernet0
interface Serial0
no ip address
no ip mroute-cache
no keepalive
no fair-queue
clockrate 148000
cdp enable
interface BRI0
no ip address
encapsulation ppp
dialer-group 1
interface Dialer1
encapsulation ppp
dialer pool 20
dialer-group 1
router ospf 10
default-information originate
ip classless
no ip http server
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
01-20-2003 09:51 AM
You are running OSPF on the ISDN line. That will produce a hello packet every 10 seconds, and your idle timeout is 900 seconds. Your dialer list permits all IP packets, including OSPF, so the line stays up.
Mark
01-20-2003 10:25 AM
Since you have "backup delay 10 30" configured, the backup isdn line should be disconnected (dialer 1 interface) after 30 secs once the primary line come up. So you need to wait till 30 secs to have dialer 1 interface go back to standby mode. Pl. verify that how loag the dialer interface stay connected after primary line comes up.
