frame relay
carl_townshend
is this a type of service/line like isdn/dsl etc or is it just an ecapsulation like ppp, hdlc etc ?
scottmac
Level 10
Level 10
Well, given the question, it's both.
You can use Frame-Relay encaps on back-to-back routers in the Lab (usually run through a FR switch for more than two PVCs / paths) ....
Or
You can order Frame-Relay service through a provider (which uses Frame-Relay encaps) the same as you'd order ISDN, POTS, or a P2P link.
It's usually deliverd on a T1/E1 or Fractional T1/E1
Good Luck
Scott
How would I set this up in a lab, can anyone give me an example config ?
