Webcast-Catalyst9k
frame relay
When setting up frame-relay mappings, say ip x.x.x.x dlci 100 etc, do you still need to put an ip route in or has this already done it ?
VIP Purple
Re: frame relay
Hello Carl,
wether you use dynamic mapping or static mapping, the only connectivity will be between the directly connected frame relay interfaces. So, for example:
interface Serial0
ip address 192.168.1.1 255.255.255.252
encapsulation frame-relay
frame-relay interface-dlci 102
will allow that router to reach the other side, 192.168.1.2 in this case, without any sort of routing.
interface Serial0
frame-relay map ip 192.168.1.2 102 broadcast
has the same effect. In order to have reachability for any other networks, you will need to use either static routes or a routing protocol...
Does that make sense ?
GP
Re: frame relay
What will be the config say on the 192.169.1.2 router ?
VIP Purple
Re: frame relay
Hello Carl,
the config would be almost identical, except for the IP address and the DLCI. On the other side, it would be:
interface Serial0
ip address 192.168.1.2 255.255.255.252
frame-relay interface-dlci 201
interface Serial0
frame-relay map ip 192.168.1.1 201 broadcast
Have you set up your own router/frame-relay switch, or is this an ISP-provided environement ?
GP
Re: frame relay
do you have to put in the dlci backwards on the opposite side then ?
105
