frame relay
Can anyone tell me how to configure frame relay between 2 sites, using inverse arp, and without inverse arp .
thanks
Silver
Re: frame relay
carl,
you can find whatever you want in frame relay configuration:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/wan_c/wcdfrely.htm
remeber to rate the post if it helps
regards
Devang
Re: frame relay
in addition to the other posts, here is a configuration example for a frame relay connection with and without inverse-arp:
No inverse-arp configs:
Router1
interface Serial0
ip address 192.168.1.1 255.255.255.252
encapsulation frame-relay
frame-relay map op 192.168.1.1 102
frame-relay map ip 192.168.1.2 102 broadcast
no frame-relay inverse-arp
Router2
interface Serial0
ip address 192.168.1.2 255.255.255.252
frame-relay map ip 192.168.1.2 201
frame-relay map ip 192.168.1.1 201 broadcast
Inverse-arp configs:
Router1
interface Serial0
Router2
interface Serial0
Obviously, this configuration requires an actual frame relay connection. If you have a DTE/DCE cable and two routers with serial interfaces, you can also fairly easily build a back-to-back frame relay connection. Here are a couple of links to the respective setups:
Back-to-Back Frame Relay Hybrid Switching
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3c.shtml
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3b.shtml
GNT
Re: frame relay
thanks for that, so which connection do we need to do frame relay maps on, would i have to do them on both point to point and multipoint ?
Re: frame relay
how come on the first config, you have mapped its own ip on the interface as well as the remote router ?, also do you always need to reverse the dlci on the other end ? i thought the dlci can be anything, do they have to be reversed ?
107
